3 gauge din panel holder
would anyone be interested in these for 37$ shipped ?
they fit perfect into the gauge panel. not too hard to install n look great ! made out of ABS plastic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">On a civic 96-00.. would they fit in the space in front of the shifter?</TD></TR></TABLE>
Well you need a 96-98 cupholder assy. to mount din style whatever's down there. It has the mounting holes and all. The 99-00 just have a pocket witch dont work unless you go cuting **** all up and want to duck tape
some things to keep your gauges inline.
It looks like it would fit, No problem.
some things to keep your gauges inline. It looks like it would fit, No problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Is the space under the radio in a Gen3 Integra a full DIN space? Cuz it measures less than 2 1/16".</TD></TR></TABLE>
dont think it is. but i remember people used to fit two decks in that space (* old school EQ) yea imma request a mod to delete this post. i ddint know they go for so much cheaper elsewhere. =T
I believe the entire space is double din. However, the stock radio is a little larger than single din and thus the remaining space is less than a single din space.
If you have an aftermarket radio, then you will have a full single din space under the radio assuming you have the correct mount kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebullet »</TD></TR><TR><TD CLASS="quote">what does this have to do with forced induction?</TD></TR></TABLE>
go ahead n delete it. pretty much 5 min after i posted it i kinda realized its stupid so i should've taken it off however coudlnt delete the post.
If you are FI, you are more likely to have gauges.
The problem is that this really belongs in FI classifieds.
I got one of these for $20 shipped. It's actually for a VW but it fits almost perfect in the radio spot for a 92-95 civic.
My 52mm Greddy gauges fit perfect, I think you may have problems if you run defi *maybe* b/c of the bigger dial on the outside
http://www.42draftdesigns.com/mk4tgp.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 »</TD></TR><TR><TD CLASS="quote">i wish they had these for integras..</TD></TR></TABLE>
I wish they made the cluster gauge holder like ek's and dc's for eg's
true. I have an ek civic with the dual guage pod bezel also, I like that, makes use of wasted space.
I just ordered one of these 3 gauge din holders for my eg from that 42.....website.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackANESE »</TD></TR><TR><TD CLASS="quote"> I think you may have problems if you run defi *maybe* b/c of the bigger dial on the outside
That is where i got mine from, and i have 3 defi d gauges in there, and they do stick out, it doesnt look that bad, but i do wish that they would recess into the panel.
how do these mount? i've seen the hks din panel which includes a cage to mount to the stock radio locations (see below), but i dont see how this would stay in place and not get thrown out on a hard launch. please share, thanks.
hks
42draftdesigns
omori
hks
42draftdesigns
omori
I wanted to bump this post to get more DIN gauge panel information for Integras. The problem with the Integras is they have 1 DIN of free space in the center dash but these DIN plates are bigger than 1 DIN. They are typically 2 1/4" where 1 DIN is 2".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8T_EG »</TD></TR><TR><TD CLASS="quote">how do these mount</TD></TR></TABLE>
I ran this one for a while:
It just pops in via locking tabs on the side. But the basic cheap design is pretty crappy IMO. It doesn't hold very well and also tehre is gaps where it angles out. Miens would always pop out about 5mm whenevr I hit bumps or jsut drive around. Kinda got anoyying so I redid my entire setup.
Before:
http://gallery.tchleung.com/al...7.jpg
After:
http://gallery.tchleung.com/al...1.jpg
Before:
After:
