Oil ?
Old Jun 7, 2004 | 07:59 PM
Lshatchy91's Avatar
Default Oil ?
My oil light comes on at low rpms. like under 1k but it is fine when it is above that ..anyone have a clue on what it could be?
Old Jun 7, 2004 | 09:01 PM
DXDOHCVTEC's Avatar
Did you check your oil level? That is oil an pressure light. It comes on when the oil pressure is low. If the light comes on cause it is supposed to (meaning the sending unit is not bad) and the oil level is fine, then you got internal problems.
Old Jun 7, 2004 | 09:24 PM
Lshatchy91's Avatar
Default Re: (DXDOHCVTEC)
Ya the oil level is fine .
Old Jun 7, 2004 | 10:23 PM
4crx4me's Avatar
Default Re: (Lshatchy91)
Bad oil sender, loose or broken wire at sender. Bad piston rings, leaky valve stem seals, bad oil pump, stuck oil pump relief valve, clogged pick-up screen. Scored cylinder bores
Just some of the causes
Old Jun 8, 2004 | 08:31 AM
Lshatchy91's Avatar
Default Re: (4crx4me)
k thanks
Old Jun 8, 2004 | 11:28 AM
URA91hatch's Avatar
what 91 dx parts do u got??
Old Jun 10, 2004 | 12:31 PM
Lshatchy91's Avatar
If there was a dent in the oil pan would that cause the light to come on..maybe if the dent was on the sensor?????
Old Jun 10, 2004 | 12:38 PM
6MTV6's Avatar
Or the bottom of the pan might be pushed up against oil sump.
Old Jun 10, 2004 | 08:27 PM
Lshatchy91's Avatar
Default Re: (Bishop4G)
Is there anything in the front cause thats where the dent is
itzyaboyzeem03
Jul 1, 2016 04:40 PM
slow_low_eddie
Aug 20, 2014 07:04 PM
IBriaIN
Feb 27, 2011 08:28 PM
coronadrinker
Nov 18, 2006 04:05 PM
integra_94
Aug 31, 2004 09:10 PM
