swap day 3.
Old Jun 7, 2004 | 07:17 PM
terminaloverlowd's Avatar
Default swap day 3.
step one - climb under car to remove 'bitch pin'.
step two - find bitch pin.. think for a couple minutes.
step three - come inside, search H-T for 'bitch pin'.
step four - try a few suggestions, with no luck.
step five - turn off garage lights, wash up, and make a note to buy the proper punch tomorrow..
heh.. it's beer time.
Old Jun 7, 2004 | 07:50 PM
mr. carpenter's Avatar
Default Re: swap day 3. (terminaloverlowd)
you could search. there are a couple of ways to get it out. what i do is to get an old drill bit that will fit in the hole and with a 6 lb. sledge hit it into the pin while holding the bit with a pair of vise grips. there was a thread with a pic of a guy replacing it with a nut and bolt but i can't find it.
Old Jun 7, 2004 | 08:27 PM
Full Race A6's Avatar
Default Re: swap day 3. (mr. carpenter)
bitch pin?
something to do with the axles coming out right?
Old Jun 7, 2004 | 09:12 PM
Default Re: swap day 3. (W O T)
the bitch pin holds the shift linkage to where it mounts to the tranny.
Old Jun 7, 2004 | 09:24 PM
crxgator's Avatar
i hate that pin...its such a...
well good luck with the rest of the swap...
Old Jun 8, 2004 | 05:39 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">there was a thread with a pic of a guy replacing it with a nut and bolt but i can't find it.</TD></TR></TABLE>
Is this the thread you were thinking of?
https://honda-tech.com/zerothread?id=881099
Old Jun 8, 2004 | 06:56 AM
Default Re: swap day 3. (keithv)
yes. gotta love teamwork.
Old Jun 8, 2004 | 07:09 AM
i'm gonna stop by sears and get the right tool for the job, then hopefully make short work of it this evening.. it's the only thing keeping me from pulling the D15.. heh
Old Jun 8, 2004 | 07:27 AM
kur0ryu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by terminaloverlowd &raquo;</TD></TR><TR><TD CLASS="quote">i'm gonna stop by sears and get the right tool for the job, then hopefully make short work of it this evening.. it's the only thing keeping me from pulling the D15.. heh</TD></TR></TABLE>
You just need a proper sized punch, don't get one of those that gradually get bigger, get the punch that is same diameter all the way down the shaft. I had problems with the ones that gradually get wider, while the same-diameter ones pop bitch pins out like magic.
Old Jun 8, 2004 | 07:28 AM
APEX CRX's Avatar
Old Jun 8, 2004 | 11:36 AM
Default Re: swap day 3. (APEX CRX)
ok.. no luck at sears, napa, or the local hardware stores..
second best alternative ?
(i've been looking for an 8mm punch with the **** on the end that goes inside the hollow part of the bitch pin)
easier to go from the top or from the bottom..
i've been pounding away from underneath..
Old Jun 8, 2004 | 01:12 PM
vitrox's Avatar
just jack the car up a bit more and pull the motor with the linkage still attached, thats what I did with my d16..
i just pulled the linkage off once it was out of the car.. wayyyy easier.
Old Jun 8, 2004 | 01:56 PM
pntballfreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by terminaloverlowd &raquo;</TD></TR><TR><TD CLASS="quote">ok.. no luck at sears, napa, or the local hardware stores..
Try a 4mm socket (like the one pictured) fitted onto a 1/4in extension (3inch). Hammer from the bottom up. Worked for me...
Old Jun 8, 2004 | 02:39 PM
b16_madman's Avatar
Default Re: swap day 3. (kur0ryu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kur0ryu &raquo;</TD></TR><TR><TD CLASS="quote">
You just need a proper sized punch, don't get one of those that gradually get bigger, get the punch that is same diameter all the way down the shaft. I had problems with the ones that gradually get wider, while the same-diameter ones pop bitch pins out like magic.</TD></TR></TABLE>
yes do that, even my mechanic friend didn't have the proper bi*** pin removal punch
Old Jun 8, 2004 | 02:52 PM
Eresuncabron's Avatar
Default Re: swap day 3. (B16_madman)
Remove the shift rods from the shifter instead, just leave them attached to the trans.
definately works out well... i've done this 2x
Outsane's Avatar
a long 10mm bolt works good....just like the one holding in the stabalizer bar to the transmission
Old Jun 8, 2004 | 02:53 PM
Harry_Randal's Avatar
Default Re: swap day 3. (Eresuncabron)
I use a 1/4 inch extension... works everytime. Of course it takes a bit of pounding but I have never put my project away because of a linkage pin... just hit hit hit hit hit... at first it will not move... but once you get it moving it seems to come out pretty good
Old Jun 8, 2004 | 03:44 PM
ThefirstPACT's Avatar
Default Re: swap day 3. (Harry_Randal)
Damn air hammer, i love air!
Old Jun 8, 2004 | 03:48 PM
MENACE's Avatar
Default Re: swap day 3. (ThefirstPACT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThefirstPACT &raquo;</TD></TR><TR><TD CLASS="quote">Damn air hammer, i love air!</TD></TR></TABLE>
yeah i tried to get it out with a hammer at first then after a few hits i noticed i was wasting my time. So i pulled out the air hammer and 5 seconds later the linkage was off. Air is the greatest
Old Jun 8, 2004 | 03:52 PM
USDM 4G VTEC's Avatar
i use a med size philips screwdriver... sit it on top of pin from the top.... use the pipe from my floorjack and place it on top of screwdriver and wack it with a hammer..... takes 3 seconds to do
Old Jun 8, 2004 | 05:35 PM
Smokinsax's Avatar
The Boot
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i use a med size philips screwdriver... sit it on top of pin from the top.... use the pipe from my floorjack and place it on top of screwdriver and wack it with a hammer..... takes 3 seconds to do</TD></TR></TABLE>
with the engine inside the bay still???
Old Jun 8, 2004 | 09:31 PM
Default Re: (Smokinsax)
got it...
i used the screwdriver/jack handle method..
a quick how-to... heh
https://honda-tech.com/zerothread?id=890127
Old Jun 8, 2004 | 11:07 PM
Synth124's Avatar
Great Neck tools(autozone) has the proper size punch, you need to buy the set sadly, but hell it gets it out real quick!
Old Jun 8, 2004 | 11:10 PM
Default Re: (Synth124)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synth124 &raquo;</TD></TR><TR><TD CLASS="quote">Great Neck tools(autozone) has the proper size punch, you need to buy the set sadly, but hell it gets it out real quick!</TD></TR></TABLE>
did that.. bought the set.. had to end up coming from above with a screwdriver/jack handle..
Old Jun 8, 2004 | 11:56 PM
DC 2's Avatar
Default Re: (terminaloverlowd)
I just use a fat phillips head that will still fit through the hole, duct taped to a long *** 1/2 extension. Throw it in 4th and attack it from the top. Works like a charm.
Only takes a minute for a bitch pin that can take hours.
jvaughn
26
Mar 16, 2008 06:25 PM
champ1986
Jan 30, 2008 11:20 PM
Pr0ject93hb
Sep 11, 2006 11:11 AM
sivik2nr
Jan 15, 2003 08:38 AM
