car feels weird after stock cams put in....help
Old Jun 7, 2004 | 06:48 PM
JunIntegra's Avatar
Default car feels weird after stock cams put in....help
well just put my stock cams back in from the skunk2 stage 1's. the car seems really hesitant and less responsive even though i remember it was way better before i put in the stage 1's. does the ECU have to adjust back to the stock cam settings (a/f ratio) from the adjustments it made for the skunk2 cams?
also, the car seems to jerk more when letting off the gas and getting back on the gas...what could that be from??? couls cam or ignition timing cause that??
Old Jun 8, 2004 | 08:22 PM
JunIntegra's Avatar
Default Re: car feels weird after stock cams put in....help (JunIntegra)
anyone?
Old Jun 9, 2004 | 10:34 AM
showtymers619's Avatar
* B A N N E D *
you do a valve adjustment?
Old Jun 9, 2004 | 03:48 PM
JunIntegra's Avatar
Default Re: car feels weird after stock cams put in....help (ShowTymers619)
no, we didnt do a valve adjustement. he insisted it didnt need one but i think he was wrong. the motor doesnt sound any louder as far as ticking goes....
Old Jun 9, 2004 | 06:30 PM
mmuller's Avatar
Mad Scientist
what does your ignition timing look like?
Old Jun 9, 2004 | 06:36 PM
JunIntegra's Avatar
Default Re: car feels weird after stock cams put in....help (mmuller)
not sure but i can have it checked. so do i absolutly need a valve adjustment or no?
Old Jun 9, 2004 | 06:41 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunIntegra &raquo;</TD></TR><TR><TD CLASS="quote">not sure but i can have it checked. so do i absolutly need a valve adjustment or no?</TD></TR></TABLE>
yes, and check ig. timing
Old Jun 9, 2004 | 08:10 PM
Wafler's Avatar
In my case, I just put in S2S1's and the car feels no quicker or more responsive than before, and I've done the valve adjust and ignition check. Do we do the common wrong things here? What to do?
Modified by Wafler at 6:00 AM 6/10/2004
Modified by Wafler at 6:01 AM 6/10/2004
Old Jun 9, 2004 | 09:41 PM
mmuller's Avatar
Mad Scientist
Default Re: car feels weird after stock cams put in....help (Wafler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wafler &raquo;</TD></TR><TR><TD CLASS="quote">In my case, I just put in S2S1's and the car feels no quicker or more responsive than before, and I've done the valve adjust and ignition check. Do we do the common wrong things here? What to do?
because you prolly need to tune them.
Old Jun 10, 2004 | 08:24 AM
JunIntegra's Avatar
[QUOTE=Wafler]In my case, I just put in S2S1's and the car feels no quicker or more responsive than before, and I've done the valve adjust and ignition check. Do we do the common wrong things here? What to do?
well when i 1st put mine in, it was kinda the same too. vtec lagged till about 5600rpm. but i think thats just a tune issue.
my exhaust got alot louder and doesnt seem to accelerate in some places even though rpms are moving up.
and from my experience, when your exhaust gets louder, you have a combustion problem. im sure many of you have noticed this
Old Jun 13, 2004 | 06:17 PM
JunIntegra's Avatar
well i was thinking. does the belt tensioner have to be re-tensioned after also? see my cuzin really streched it to get back on with out tensioner. so if the belt is a lil loose, would that cause the hesitation between on and off throttle response?
Old Jun 13, 2004 | 06:40 PM
spaceman's Avatar
maybe it skipped a tooth...make sure the timing is right then tighten the belt if it needs it...good tune-up after that should be good to go
Old Jun 13, 2004 | 07:07 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunIntegra &raquo;</TD></TR><TR><TD CLASS="quote">well i was thinking. does the belt tensioner have to be re-tensioned after also? see my cuzin really streched it to get back on with out tensioner. so if the belt is a lil loose, would that cause the hesitation between on and off throttle response?</TD></TR></TABLE>
holy **** that's some amature wrenching! yes, correctly tension the belt after inspecting closely for cuts from jaming it over the gear. replace it if it's cut up at all.
Old Jun 16, 2004 | 07:48 AM
JunIntegra's Avatar
Default Re: car feels weird after stock cams put in....help (Bailhatch)
ok everything is all set. got my honda mechanic to take care of it.
one exhaust tooth on the gear was off. thats it. thanks fr the help guys
ntensemex505
Engine Management and Tuning
Sep 14, 2009 12:09 PM
weak_sauce
21
Feb 15, 2006 07:53 PM
kuki
Jan 26, 2005 06:51 AM
fastbrakes
Oct 28, 2003 08:03 PM
B00ST2nR
Aug 17, 2002 10:28 PM
