2 questions, VSS reading and how to tell if your fan is working?
Old Jun 7, 2004 | 06:09 PM
originalbadbob's Avatar
Default 2 questions, VSS reading and how to tell if your fan is working?
I am getting a cel reading #17 that my speed sensor is I guess not working, should I just get a new one?........and how long does a car have to run before the fan engages?
I just put in a new engine and I had none of these problems before? I have checked that everthing is plugged in etc.....
HELP PLEASE!!!!!!!!!!!!!
Thanks !
If anyone has any I deas you can email me tonight at oldskoolkustoms@aol.com
Old Jun 7, 2004 | 06:13 PM
coot_er's Avatar
Default Re: 2 questions, VSS reading and how to tell if your fan is working? (originalbadbob)
i would like to know about the fan too.
Old Jun 7, 2004 | 06:19 PM
CyniKal.Mindset's Avatar
Default Re: 2 questions, VSS reading and how to tell if your fan is working? (coot_er)
well if ur speedo works then ur vss works...if it dont then you should check the cable where it goes to the tranny and where it connects to the cluster...if its all connected securely then u prolly need a new cable
as for the fan...takes my car about 10min at idle for the fan to kick in on a warm day
Old Jun 7, 2004 | 06:37 PM
ih8sndq's Avatar
Default Re: 2 questions, VSS reading and how to tell if your fan is working? (CyniKal.Mindset)
i'm getting a code 17 also. Everything on my gauge cluster works also and i don't now what it is. What could it be?
Old Jun 7, 2004 | 07:53 PM
mr. carpenter's Avatar
Default Re: 2 questions, VSS reading and how to tell if your fan is working? (ih8sndq)
try to reset the ecu by disconnecting the pos. batt. cable for 10 secs. . what swap did you do?
Old Jun 7, 2004 | 08:21 PM
Default Re: 2 questions, VSS reading and how to tell if your fan is working? (mr. carpenter)
reset the ecu by pullin the ecu fuse under the hood...leave it out for like 5min.
doin it this way u dont have to reset you clock and radio stations
Old Jun 7, 2004 | 08:57 PM
blah13's Avatar
To check your fan, on the back of the block you have a black boot right next to the oil filter, pull this off and theres 2 wires. Put a paper clip/wire between the 2 wires. Turn your ignition on and it should turn on, if not then start the car, I'm not sure if it has to be running or not. This will let you know if your fan works.
However the switch may be bad, where it ownt turn on at the right time or never. In which case I belive you have to remove the switch, put it in water, heat the water and test for current at a certain temp....not a fun thing. If the fan doesnt come on on its own simply run a remote switch (get from radio shack or ACE for like $2) in between the 2 wires, just remember to turn your fan on.
j4s0n1337
52
May 13, 2011 09:55 PM
Schultzie
11
Jul 18, 2010 06:11 AM
eliasromero
Apr 13, 2007 12:56 PM
SpeedSin
Oct 25, 2005 11:50 AM
JBBNJ609
Feb 5, 2004 02:10 PM
