95 Civic HELPPP!!
Old Jun 7, 2004 | 06:04 PM
lilCivic's Avatar
Default 95 Civic HELPPP!!
i have a little problem my 95 civic (1.6 SOHC vtec)..is a manual trans when i put it one 1st gear and floor it the car is hesitating then it will pick up in like 2 seconds..i dont know why?? and when my vtec hits i am burning a little oil can any help thank you!!!
Old Jun 7, 2004 | 07:17 PM
mrjdmcivic's Avatar
Default Re: 95 Civic HELPPP!! (lilCivic)
sounds like its a tps sensor with a bad spot in it or a fuel pump going bad
Old Jun 8, 2004 | 03:42 PM
lilCivic's Avatar
whats a tsp sensor and where is it located.?? Thanx
Old Jun 8, 2004 | 03:47 PM
HyBriDcxR's Avatar
When you hit vtec it will burn up some oil. Nothing to worry about.
Old Jun 8, 2004 | 07:01 PM
phobi9's Avatar
Default Re: (lilCivic)
tps sensor is the Throttle Position Sensor, and it should be located on the Throttle Body itself, but I'm not sure.
Old Jun 8, 2004 | 07:16 PM
Chiovnidca's Avatar
Default Re: 95 Civic HELPPP!! (HyBriDcxR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyBriDcxR &raquo;</TD></TR><TR><TD CLASS="quote">When you hit vtec it will burn up some oil.</TD></TR></TABLE>
Why would it do that?
Old Jun 8, 2004 | 08:07 PM
IVI's Avatar
IVI
Default Re: 95 Civic HELPPP!! (Chiovnidca)
what makes everyone think its his tps? it sounds like he needs to get a tune-up. his car is choking. change your plugs, or at least inspect them, as well as your cap and rotor and wires. it sounds like a spark problem.
i dont think its a tps.
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Why would it do that?</TD></TR></TABLE>
yah why would it do that?
unless he has major bottom end wearage.
is wearage a word ?
Old Jun 8, 2004 | 08:08 PM
mikehawkBUiLT's Avatar
i had the same problem, changed my spark plugs and all is well
Old Jun 8, 2004 | 08:26 PM
ApexIS300's Avatar
Default Re: 95 Civic HELPPP!! (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">what makes everyone think its his tps? it sounds like he needs to get a tune-up. his car is choking. change your plugs, or at least inspect them, as well as your cap and rotor and wires. it sounds like a spark problem.
Agreed
Old Jun 8, 2004 | 08:38 PM
stew18564's Avatar
i have the same problem right now, and i have all new wires and plugs bc thats what i think it is, so im goign to go ahead and do that this weekend and see what happens
stew
Old Jun 9, 2004 | 05:31 PM
lilCivic's Avatar
i put it in new spark plugs and wires like 7 days ago...i put NGK ..and the wires are bosch...well its still the same thing...i changed the PVC its running smoother...u think its the gas filter??? idk thank u EVERY1
Marcels Kuztoms
Oct 20, 2012 06:38 PM
dwr1977
Feb 1, 2012 05:45 PM
speedy_beedee
15
Jan 4, 2008 04:47 PM
ProjectDarkBlack
Honda S2000
20
Sep 29, 2007 03:24 PM
Steven5210
Honda Civic (2006 - 2015)
14
Jan 9, 2007 07:58 AM
