CRX W/b16a swap..which axles??
i have a JDM B16a swap in my 90 Crx si...i need a replacement axle. it uses 90-=93 Acura Integra axles right...i got the one for a GSR w/out abs...is this correct...which axle do i need?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SC0TT »</TD></TR><TR><TD CLASS="quote">If the intermediate shaft is from a 90-93 Integra, then a 90-93 non-abs integra axle will work.
If the axle you have is from a 94+ GSR, then you need a 94+ I Shaft.</TD></TR></TABLE>
shiithook
May 28, 2002 12:02 PM
