HELP Can't get into gear. Pressure Plate? Clutch..
Old Jun 7, 2004 | 03:36 PM
zad5's Avatar
Default HELP Can't get into gear. Pressure Plate? Clutch..
I can't get my car into gear any of the gears. The clutch is not slipping if i turn off the car put it into first the car does start and drive and the clutch doesnt slip. wut do you guys think it is because im not fully sure. pressure plate maybe throwoutbearing? thanks
Old Jun 7, 2004 | 08:01 PM
yOnKiNaToR's Avatar
Default Re: HELP Can't get into gear. Pressure Plate? Clutch.. (zad5)
did it slowly start getting worse to the point you're at now? i had the samething happen to me...it was a bad pressure plate and a spring got loose...car left me stuck in my driveway...i would just buy a whole new clutch kit cause more than likely something else may need replacing.
Old Jun 7, 2004 | 09:12 PM
zad5's Avatar
yo thanks a lot man for actually posting me and a friend came to the conclusion that it was the pressure plate but wanted to make sure. the car has a real heavy clutch when i bought it did many drag runs on it learned how to drive a stick on it. it was slowly getting hard to get into gear i changed tranny fluid and then one day it happened.
harker
Transmission & Drivetrain
18
Feb 7, 2025 08:42 PM
EG_LS
15
Sep 3, 2007 06:01 PM
erikiksaz1
Jun 10, 2007 10:38 AM
