weird noise from the front end
Old Jun 7, 2004 | 02:59 PM
virusiidx's Avatar
Default weird noise from the front end
I'm getting this weird noise in the front end whenever at low speeds, kinda sounds like paper dragging or the fender liner rubbing, but i already checked that. any idea what it is?
i have a '96 ls btw.
Old Jun 7, 2004 | 04:22 PM
Axle's Avatar
Check every single little rubber bushing, boot, etc. By the way you're describing it, it sounds to me like you've got two or more parts lightly touching once they're hit whuch puts pressure on them.
Old Jun 7, 2004 | 04:25 PM
G1 TEGGY's Avatar
Default Re: weird noise from the front end (virusiidx)
hmm, scratching at low speeds.. could be your brake pads are gone, if it's doing it when the brakes are off then i'm wrong
Old Jun 7, 2004 | 04:29 PM
virusiidx's Avatar
ill double check brake pads, and check those bushings, see what happens
Andy D Knode
Apr 15, 2017 08:27 PM
pear_b
Apr 11, 2009 12:21 AM
syknxv3
Sep 21, 2008 09:00 PM
Creep
Jan 20, 2008 11:32 PM
Slammed95Cord
Nov 27, 2003 02:24 PM
