heat sheild rattle
Old Jun 7, 2004 | 02:03 PM
accordmurf's Avatar
Default heat sheild rattle
anyone's heat sheild from their catalytic converter started rattlin'? i have a 94 ex 5speed, everytime rpms go low, the sheild rattles like its gonna fall off. i tried new bolts and bigger washers but my question is.. is there something like a rubber washer or plastic that i can use or would that get to hot and melt off? anyone else had this problem .. its very annoying
Old Jun 7, 2004 | 02:21 PM
tjohnson329's Avatar
Default Re: heat sheild rattle (accordmurf)
i am having the same problem, my heat sheald is rattling in the same way yours is. I had it fixed once before but don't know how to fix it myself. if you figure out what it is let me know.
Old Jun 7, 2004 | 02:27 PM
b_ron007's Avatar
might be the bracket for the headers....the one connected to the block. i thought it was the shield to but over looked the bracket, so i insisted it was the cat shield, took all the shields off but still made the noise. then took another look. a few people had the same problem, but i ignore them, but then i had a 3rd look, n sure enough, that was it.
Old Jun 7, 2004 | 03:19 PM
First Honda 1976's Avatar
I had the same rattle on my 1996 Accord , i just put a 2 1/2" Hose clamp around the end of the Sheild and tightened it up . you may need a Clamp front and rear of Sheild . Or just use a Wire hanger in the same position wrap it around the end and twist with a pair of Plyers till it's tight around the pipe . NO MORE RATTLE . Good Luck
Old Jun 7, 2004 | 03:29 PM
Brent S's Avatar
i just cut mine off. no more rattling, and no problems with the heat shield not being there. Took it off over a year ago.
Old Jun 7, 2004 | 04:46 PM
Default Re: (Brent S)
If you remove the Sheild ,Just be carfull if you park in the GRASS at all , i've seen the heat from a catylitic converter start the grass underneath the car on fire . It in turn burned the car , the Catylitic Converters get HOT, especially after long rides.
Old Jun 7, 2004 | 04:54 PM
accordmurf's Avatar
Default Re: (First Honda 1976)
dont think i'll be removing the heat shield, it is there for a reason, to sheild heat!!!!
not a bad suggestion but no thanks, this weekend i'll check out the header bracket, i dont believe thats it but i tightened everthing and tried to rock it around and it would not move so maybe i should try new things
Old Jun 8, 2004 | 07:25 AM
Default Re: (accordmurf)
Run the car when cool and jack up the side of the car, when you hear the rattle , push up on the Heat sheild when noise stops you'll know if the heat sheild has rusted loose . If so Hose Clamp it front and rear and no more noise and it will be secure . GOOD LUCK
Hyard24
Sep 17, 2008 12:51 PM
Way2Fast4DoorAccord
Oct 29, 2004 01:39 PM
quikrpm'z
Oct 5, 2003 05:19 AM
92TEGsrSC
Aug 5, 2003 01:28 PM
92TEGsrSC
Jul 20, 2003 07:44 PM
