SHIFTING FOR H22 TRANNY IN EG BODY/ 3 OR 4 MOTOR MOUNTS?
What is the shifting like on the h22 tranny? Is it all cable? If so how would it be converted for it to be used in a civic? Does the engine require 3 or 4 motor mounts for it to be mounted in a civic? and where are they mounted? If anyone has an eg with an h22 swap and would post pictures it would be very helpful.
Most use 3 mounts and sometimes 4 including the front cross member. It is a cable set up. The cables are ran into the car through a hole to the shifter assembly but a small amount of the old shifter location needs to be cut away to fit the prelude shifter.
WHATS VTEC
Mar 1, 2005 10:15 PM
gdrum
Feb 13, 2004 02:45 PM
