Any one know if a 1 inch difference in ground clearence Front to Rear is a Problem.
Old Jun 7, 2004 | 10:54 AM
First Honda 1976's Avatar
Default Any one know if a 1 inch difference in ground clearence Front to Rear is a Problem.
I just installed a set of 4 H&R OE Sport Springs , with Bilstein HD shocks, Using my original bumpstops from OEM shocks on new shocks , as per instructions from H&R OE Sport Springs, on My 1996 ACCORD DX Sedan . I just measured the height in FRONT from the ground to Jacking position it's 7 inches , in REAR the measurement from the ground to jacking position is 8 Inches . A 1 Inch height difference Front to Rear body ground clearance . Any way i measure it it's 1 inch higher in the Rear to Front . Is this NORMAL on these ACCORDS or is this a problem body not level. ANY HELP PLEASE OR SOME SUSPENSION SPECIALISTS . THANKS
Old Jun 7, 2004 | 02:21 PM
JDM.Accord's Avatar
Default Re: Any one know if a 1 inch difference in ground clearence Front to Rear is a Problem. (First Honda
Yeah that's pretty normal. It may settle a little bit over time and if not I wouldn't worry about it too much. A lot of those springs are made so the front is lower then the back so it looks 'aggressive.'
Old Jun 7, 2004 | 03:11 PM
My Bad !!! I installed the LOWER Spring perch upside down on the shock , Causing the Ride Height to be raised 1 inch in the Rear . I have to remove the Bilstein shock and spring, and take spring off and turn the Spring perch over, and put the spring back on and the Ride height should drop the 1 inch . And hopefully my handling will improve , the car will be lower front and rear like H&R OE Sport springs are supposed to lower the ride height. Thanks to all for HELP .
88LXi68
Suspension & Brakes
18
Aug 8, 2018 11:13 AM
w211 ryda
Oct 1, 2009 06:04 PM
Robstunner4
Suspension & Brakes
Oct 8, 2006 09:22 AM
i97supratti
Suspension & Brakes
Jul 18, 2006 04:24 PM
5gccord
Jun 13, 2003 04:59 AM
