Hub caps
Old Jun 7, 2004 | 09:09 AM
haileIjah's Avatar
Default Hub caps
SO i have a very basic Honda Accord with factory everything, I had to replace two tires and have a problem getting the damm hubcaps back on the wheels. What am I to do?[]
Old Jun 7, 2004 | 10:18 AM
SJSlots's Avatar
Default Re: Hub caps (haileIjah)
You are putting the hubcaps on before the wheel locks correct? Are you making sure the valve stem cut-out is in line with the actual valve stem?
Old Jun 7, 2004 | 04:51 PM
accordmurf's Avatar
rubber mallet
Old Jun 7, 2004 | 10:40 PM
IVI's Avatar
IVI
Default Re: Hub caps (SJSlots)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJSlots &raquo;</TD></TR><TR><TD CLASS="quote">You are putting the hubcaps on before the wheel locks correct? Are you making sure the valve stem cut-out is in line with the actual valve stem?</TD></TR></TABLE>
its simple enough. make sure you check these. also the lug nuts have a little rubber condom end looking thing on them. they need to be there to hold the hubcap on there.
IceySC
Oct 9, 2008 11:34 AM
doubleshotz
Sep 14, 2007 02:49 PM
metal-x
Sep 17, 2004 01:29 PM
RaVAGE00
Aug 8, 2004 12:51 AM
JFG Kevin
May 12, 2004 03:44 PM
