Rear tie bar?
i dont see much companies making rear lower tie bars. i have a 2000 civic si with 19MM ST rear sway bar. i want a good tie bar to go with the sway, any one got any suggestions? im thinking of getting the skunk2, does JIC or cusco make one?
While your at it i would suggest replacing your rear sway bar for a beefier one.
Try searching though - https://honda-tech.com/zerosearch
Modified by Built2Spill at 12:03 PM 6/7/2004
please read my first post before telling me to search. i already upgraded to a 19MM ST(suspension techniques) sway bar.
i notice the SRR is pretty cheap. i have to look into it. some feedbacks on it would help.
also..where can i find the cusco rear tie bar? i search but i cant find it. i see a couple of no name brands but i really wouldnt want to try. more suggestions would be great..thanks
i have the srr tie bar and sway bar kit, i noticed a big difference with it, however i installed them both at the same time, so i dont know exactly what the tie bar did... here's some pics of it on my ek https://honda-tech.com/zerothread?id=888249
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anekin007 »</TD></TR><TR><TD CLASS="quote">please read my first post before telling me to search. i already upgraded to a 19MM ST(suspension techniques) sway bar.
also..where can i find the cusco rear tie bar? i search but i cant find it. i see a couple of no name brands but i really wouldnt want to try. more suggestions would be great..thanks</TD></TR></TABLE>
here is where i have got my cusco products, talk to brad he has helped me out and is good to deal with.
http://www.napsusa.com
http://www.napsusa.com/napsusa/317-311-BJ18.html
http://www.napsusa.com/napsusa/317-311-BJ24-.html
also..where can i find the cusco rear tie bar? i search but i cant find it. i see a couple of no name brands but i really wouldnt want to try. more suggestions would be great..thanks</TD></TR></TABLE>here is where i have got my cusco products, talk to brad he has helped me out and is good to deal with.
i wouldn't buy one if you already have a sway. the only reason i see buying a tie bar is to help as a brace for the sway bar if you don't need one for the sway bar then dont' buy one
^Sammy]!.
Feb 7, 2004 08:15 AM
slocrxsi
Sep 5, 2003 02:03 PM
VTEC-DA
Oct 18, 2002 05:54 AM
