Is the heater core work with the a/c unit in any way?
Old Jun 7, 2004 | 08:10 AM
TedR719's Avatar
Default Is the heater core work with the a/c unit in any way?
Just wondering if the heater core is in relation with the a/c in the car... How does this work?
Old Jun 7, 2004 | 09:57 AM
JimBlake's Avatar
Default Re: Is the heater core work with the a/c unit in any way? (futuresi)
Air flows thru the AC evaporator first, then thru the heater core. So if you have the AC & heat both turned on, it cools the air then heats it back up. If it's raining or if it's really damp, this is like a dehumidifier to dry the air. If you don't need to dehumidify the air, then it's just a waste where the AC & heat are working against each other.
Old Jun 7, 2004 | 11:02 AM
crx2fast's Avatar
i hope you dont have to replace it. iv done one before and it is not fun let me tell you
Old Jun 7, 2004 | 11:58 AM
TedR719's Avatar
Default Re: Is the heater core work with the a/c unit in any way? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Air flows thru the AC evaporator first, then thru the heater core. So if you have the AC & heat both turned on, it cools the air then heats it back up. If it's raining or if it's really damp, this is like a dehumidifier to dry the air. If you don't need to dehumidify the air, then it's just a waste where the AC & heat are working against each other.
Thanks
Frizou
Aug 15, 2017 06:48 AM
Revolver123
Honda Civic (2001 - 2005)
Jun 12, 2008 03:08 PM
kevinm30
Honda Civic (2006 - 2015)
16
Jun 25, 2006 10:05 AM
skata89
Oct 16, 2005 05:00 PM
