97 civic axel replacement
Old Jun 7, 2004 | 08:02 AM
cab525's Avatar
Default 97 civic axel replacement
does anybody have a step by step breakdown for replacing the passenger side (or both sides) axel from start to finish? my car is a '97 Civic HX standard transmission & i have a complete axel/CV assembly from hub to trans.
Old Jun 7, 2004 | 08:28 AM
JDMahrpr's Avatar
Default Re: 97 civic axel replacement (cab525)
search or go to the FAQ uptop, its in the first post I believe.
Old Jun 7, 2004 | 10:00 AM
jolt-tsp's Avatar
I recommend getting a haynes or better yet, a helms manual. Basically, you take off the axle nut, loosen the lugs, jack up the car, take off the wheel, unbolt the crown bolt on the bottom of the control arm, separate the ball joint, push/pull/bang the axle out of the hub, yank the axle out of the tranny. Reverse for install. I may have missed steps, but thats what the manuals are for.
nuber1zero
Jun 19, 2014 07:30 PM
thw_goalie
Aug 12, 2012 10:39 AM
exsquid
May 3, 2008 10:23 AM
w0ng_sta
Jan 3, 2007 07:05 PM
antiabercrombie
11
Mar 25, 2003 06:37 PM
