SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle"
Old Jun 7, 2004 | 07:38 AM
TECH43 RACING INC.'s Avatar
Default SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle"
nothing too great yet, k24 motor is mocked up for header/exhaust fitment/radiator etc.
I was gonna do the mounts myself, but hasport's kit is nice, so I said forget it. this kit is not available yet, so please dont ask, and dont call hasport asking for it either. be patient. it will be out very soon.
the motor going in soon: 2464cc, custom pistons, 11.5 to 1, ported k20a head, custom cams, custom header/exhaust, aem ems/custom harness. just a motor to get it out there and running, hopefully it will make good power. i'm curious to see how long it will live with the 99mm stroke.
big thanks to eric valdes aka richie valens of street image for the killer shop use.
garbage
removing the trans bracket
the right way to remove it, no sawzall's you hacks!
awesome rear bracket
AWESOME clearance.
not awesome clearance, but nothing you can do. hood will get modified. i'd rather mod the hood, than have a low pan.
k twizzle
Old Jun 7, 2004 | 07:43 AM
xJ.SLOTHx's Avatar
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (TECH43 RACING INC.)
definitley impressive to say the least...
Old Jun 7, 2004 | 08:04 AM
xtrac1's Avatar
rookn00b
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (ian)
Put it in your Insight, not the EG!!!!!!!!!!!!!!!
Old Jun 7, 2004 | 08:13 AM
Solo2Vtec's Avatar
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (xtrac1)
Lookin good Steve!
Old Jun 7, 2004 | 08:16 AM
JCushing's Avatar
is the clearance that bad just cause the k24 has a taller deck than the k20a or is it that bad with all k series?
Old Jun 7, 2004 | 08:17 AM
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">is the clearance that bad just cause the k24 has a taller deck than the k20a or is it that bad with all k series?</TD></TR></TABLE>
the k24 has a 19.7mm taller deck, plus, k's are just tall in general
Old Jun 7, 2004 | 08:21 AM
BERT-O's Avatar
NO ****.........Omniman did mention about you last weekend. Sorta wanna see this car up closed now.
Bump for another clean yellow EG.
-Bert
Old Jun 7, 2004 | 10:04 AM
JDMotive's Avatar
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (BERT-O)
good stuff...let us know what kind of numbers it put's out
Old Jun 7, 2004 | 10:13 AM
phivelug's Avatar
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (JDMotive)
wow, very nice. rhd kseries eg hatch, not many of those around
Old Jun 7, 2004 | 10:24 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Does it clear the hood? How high do you plan on revving it?
Nice work
Old Jun 7, 2004 | 10:31 AM
Miracle_X_Bar's Avatar
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (FrostyDC4)
Niice!!! Me likey likey the EG!!
Old Jun 7, 2004 | 10:33 AM
ek four's Avatar
damn, its rhd too
Old Jun 7, 2004 | 10:48 AM
ironmonkee's Avatar
Just sick. Keep up the good work, man.
Old Jun 7, 2004 | 10:50 AM
Solo2Vtec's Avatar
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (ironmonkee)
Check those MAD Yellow JDM Seats, Which are very comfortable and supportive I was very impressed.
Old Jun 7, 2004 | 10:54 AM
slofu's Avatar
what's the r/s ratio of the stock k24?
Old Jun 7, 2004 | 10:56 AM
DOMKID's Avatar
that car is a monster. Post some vids when its up and running.
Old Jun 7, 2004 | 11:23 AM
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">what's the r/s ratio of the stock k24? </TD></TR></TABLE>
1.535, pretty crappy considering the stroke is 99mm. i dont plan on it living too long. kind of an experiment/quickie throw together motor just to get it running. later i will probably destroke it and stretch the rod out with a .850 compression height piston.
Old Jun 7, 2004 | 12:18 PM
slofu's Avatar
how high can you rev it and still mesh the gears with the cable tranny, though? no sense in building it to pull to 10K rpm if you can't shift there. granted, 99mm is a long stroke; more flex/vibration/harmonics to worry about eating bearings, etc.
Old Jun 7, 2004 | 12:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">how high can you rev it and still mesh the gears with the cable tranny, though? no sense in building it to pull to 10K rpm if you can't shift there. granted, 99mm is a long stroke; more flex/vibration/harmonics to worry about eating bearings, etc.</TD></TR></TABLE>
cable shifted transmissons shift just as good as transmissions with linkages, and the way in which the gears are shifted (cables/linkages), has no bearing on how high you can rev it before it wont shift.
building in to pull 10k? who said that?
and a 99mm is never going to go to 10k, and live.
99mm cranks dont create vibration/flex/harmonics/bearing problems etc, just because they are 99mm, over revving does, regardless of stroke.
Old Jun 7, 2004 | 12:38 PM
NSTY Z33's Avatar
Mind thre morons, nice car, can't wait to see it in action. Very very impressive. I can imagine the #'s.
Old Jun 7, 2004 | 01:29 PM
ImportechPerformance's Avatar
Default Re: (JDMCRXDelSol)
Haaha i think its hilarious how you just threw a freaking k24 built 11.5 comp and just say that its just something to get it running..
It actually really hurts me cuz it seems so impossible
Old Jun 7, 2004 | 01:58 PM
Retired's Avatar
WEST COAST
Good Job Steve cant wait to see it run
Old Jun 7, 2004 | 02:18 PM
Rtype16's Avatar
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (SPARK RACING INC.)
Damn man that car is so JDM look right hand drive and everything. Hahaha Steve finally got rid of the JDM radio that doesn't work in the US. Damn radio stations... Haha. Gotta go check it out at Streetimage if you guys haven't finished it yet.
Old Jun 7, 2004 | 02:53 PM
SkRiBLaH's Avatar
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (Rtype16)
1 word:
FINALLY
and very nice job by the way... i cant wait to ride in it
Old Jun 7, 2004 | 03:50 PM
EMO-anthony's Avatar
Default Re: SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle" (SkRiBLaH)
Damn nice build! I wanna see how much power this beast is going to put down!
