installing shifter bushings???
it's not hard. unbolt the stabilizer from the car, where the shifter is, underneath the car. it's two bolts, 12mm, i believe. from there, the bushing should be visible and can come out. take out the metal sleeves and put them into the new bushing. slide the new bushing on and bolt the stabilizer back on.
The other bushing is a little harder. You might have to remove the cat, or at least unbolt it to be able to swing the shift stabilizer down. Unbolt it from the transmission case, 12 or 14mm, and don't forget how the washers go and the orientation of the bushing. Take out the old bushing and push the new one in. put the washer back in and bolt it back on and reconnect the cat and you're good to go. good luck
