Misfire at 1500 rpm
Hi guys, I have a 90 Automatic. Revs great at all rpms EXCEPT 1400-1600 rpm. I get a bad misfire and is most noticeable in first geat but can be felt in other gears if cruising at a slow speed.
It really makes the car hesitate when starting from a stop. Pretty annoying. It DOESN'T have this problem when in cold start mode though. So I'm guessing it's a fueling problem relating to an electrical part.
Anyone ever heard of this? It's distinctly a 1500 rpm problem. There is nothing else wrong with the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gofastant »</TD></TR><TR><TD CLASS="quote">Hey, that worked!
Now what? New EGR? I'd leave it like this but the check engine light comes on now.</TD></TR></TABLE>
That was just a test. Your EGR valve is good. Your EGR ports need to be cleaned out, someone posted a how-to a while back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
That was just a test. Your EGR valve is good. Your EGR ports need to be cleaned out, someone posted a how-to a while back.</TD></TR></TABLE>
i cleaned the egr and plugged it back up. The problem is still there. what next?
Hey, my car stutters sometimes and I'm wondering if we're actually having the same problem. What the hell is the EGR (i can fix just about anything but don't get me to try and tell you the actual name. Ex. "The dohickey connects to this here thingymabober and it causes the car to crank."). What does the EGR do? And where is it located?
i cleaned the egr and plugged it back up. The problem is still there. what next?</TD></TR></TABLE>
Did you clean out the EGR ports going into each individual intake runner?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Obsidian »</TD></TR><TR><TD CLASS="quote"> What the hell is the EGR
What does the EGR do?</TD></TR></TABLE>
Exhaust Gas Recirculation
It adds exhaust gas to the intake to dilute the fuel mixture during part throttle and cruise conditions.
Did you clean out the EGR ports going into each individual intake runner?</TD></TR></TABLE>
How do I do that? Some type of snake brush?
Addicted2Racing
Sep 15, 2005 07:46 AM
