d15b vtec n/a build questions
first, im building the bottom end of the stock dx d15b7 hopefuly to a 1.7, as for right now im looking for info on a good cam, gear and wondering if a fields vtec controller will help anything right now. ive heard the d15b cam is almost comperable to a comp 59300 cam, is this true? i want to get this thing as far as possible because everyone around here goes dohc, not that i have a prob with that, but everyone tells me im wasting time with the sohc, and i spent alot of time putting some of the dohc vtec guys to shame around here,and i want to prove them wrong, also how does this head respond to a port and polish, and possibly the IM? also going to go with a ls tb, ive heard this is a good upgrade. i need as much help with this as possible as im not sure what this motor responds too the most. what exhaust size should i be running? a test pipe or a high flow cat, and i heard 2.25" is good for exhaust let me know.
I have a ported manifold z6 manifold same has the d15b sohc vtec with a 60 mm throttle body.https://honda-tech.com/zerothread?id=877515. The manifold/throttle body combo totally changes the d15b sohc vtec. That stock manifold/throttle body kills top end. 2.25 inch is a good size for exhaust.
Depends on the amount of money your willing to spend.For example, If your looking for the cheap route (like I did) I got a D16Y8 manifold ,which is looked at as the "type R" intake manifold for D-series, and port matched (and polished) it to a 95 GSR TB(which I also polished). Or get the Edelbrock/AEM intake combo which recieved a great review. Made something like 20 hp supposeably. I didn't see the head your using, but the title mentions Vtec. I think the Z6 is the most recommended, and it raises the compression to around 10:1. adding p29 or ZC pistons then bumps you to around 12:1.(If I remember correctly)
Here read this and go through the links in his signature and you'll find alot of info https://honda-tech.com/zerothread?id=385741
what should i look to pay for a y8 mani. is it a direct replacement for the d15b vtec. im just using the one that came with it for now.
TyConway21
27
Oct 20, 2005 09:08 PM
