DIY Engine Grounding...What do you think?
How does that look? anybody see anywhere else i should ground?
and should i use 8awg or 4awg? i have 8awg on hand...but if 4awg will work better...
thanks
nick
ground out to the frame behind the headlight bc it has the best contact point and also the less wire you have running around the less you have to worry about having to mess with while your doing other engine work. 8 awg will do fine but in the long run 4 carries grounds better..
8awg is fine, maybe even overkill. Popular places on honda's to ground are the throttle body, intake manifold, head, transmission, vtec solenoid, alternator, and maybe thermostat housing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord »</TD></TR><TR><TD CLASS="quote">yes, it supposidly gives better performance...but it's just a project for me</TD></TR></TABLE>
i dont get it...anyone happen to know why this could give better performance? not that i doubt it, im just trying to understand this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue »</TD></TR><TR><TD CLASS="quote">
i dont get it...anyone happen to know why this could give better performance? not that i doubt it, im just trying to understand this</TD></TR></TABLE>
Making the grounds better increases the efficiency of the electrical system so it helps performance.
I like the idea. But IMO wires clutter up the accord engine bay more then it already is. Is there anyway to hide them, or mount the wires lower???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord »</TD></TR><TR><TD CLASS="quote">Use Black Wires?</TD></TR></TABLE>
Black would look cleaner
What I have found in showing vehicles is that straight lines look the best. If you could run the wires along some staight lines that would help too
Great DIY oh by the way
redfoxdreamcatcher
Mar 1, 2007 09:14 AM
kay_animation
16
Feb 2, 2003 06:32 AM
