How to take gas out of your cylinders.
Old Jun 6, 2004 | 07:57 PM
Luserkid's Avatar
Default How to take gas out of your cylinders.
I tried searching but the only thing that would come up is gas and that finds over 1000 threads which i dont have muhc time to look through all to find a answer. So if someone post a link to a good walk through of how to do this please delete this thread.
Anyway ive been having alot of problems with my car and i did a couple compression test. But the dumbass that i am at times (or lazy some might say) i left my injectors plugged in. So now i have way to much gas in my cylinders to get my car to start. Does anyone know a good way to get gas out without pulling the head? Thanks.
Old Jun 6, 2004 | 07:58 PM
xerox445's Avatar
Default Re: How to take gas out of your cylinders. (Luserkid)
crank it with the injectors umplugged, and sparkplugs out also...
Old Jun 6, 2004 | 08:02 PM
Luserkid's Avatar
Default Re: How to take gas out of your cylinders. (xerox445)
I was thinking of something like that but with spark plugs in but my friend said that the fuel wont burn because its a liquid already.
How exactly does that work with spark plugs out? Would it be sucked up through the exhaust valves?
Old Jun 6, 2004 | 08:03 PM
skip.two's Avatar
couldn't find anything either. somebody help this guy.
Old Jun 6, 2004 | 08:04 PM
xerox445's Avatar
it will get shot out the hole on the compression stroke....when all the valves are closed
Old Jun 6, 2004 | 08:05 PM
civicmatt's Avatar
Leave all four plugs out for awhile(few hours or overnight). The gas should evaporate.
Old Jun 6, 2004 | 08:06 PM
Luserkid's Avatar
Default Re: How to take gas out of your cylinders. (civicmatt)
Really? would gas evaporate just like that?
Old Jun 6, 2004 | 08:12 PM
justinh595's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">it will get shot out the hole on the compression stroke....when all the valves are closed</TD></TR></TABLE>
Old Jun 6, 2004 | 08:13 PM
xerox445's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Really? would gas evaporate just like that? </TD></TR></TABLE>
yes
Old Jun 6, 2004 | 08:14 PM
Luserkid's Avatar
Ok im going to try that and ill let you guys know how it goes tomorrow morning. Thanks
99blackcivicSi's Avatar
Here is the easiest way to do it.
1: unplug main relay
2: take out spark plugs
3: crank the car over and it will shoot gas out of the cylinders
Old Jun 6, 2004 | 08:16 PM
skip.two's Avatar
hm good to know. saved in Favorites.
Old Jun 6, 2004 | 09:16 PM
IVI's Avatar
IVI
Default Re: How to take gas out of your cylinders. (jL iLLuZiOnz 9)
dont do anything or touch anything. just leave it alone for an hour. itll evaporate.
i had so much gas in my cylinder that my motor wouldnt even crank. 20 mins later and it would crank again..
Old Jun 6, 2004 | 10:46 PM
Default Re: How to take gas out of your cylinders. (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">dont do anything or touch anything. just leave it alone for an hour. itll evaporate.
why it only takes me about 1 minute to get gas out of the cylinders or water in that rare case a customer comes in and didn't **** the motor up
Old Jun 7, 2004 | 08:04 PM
Luserkid's Avatar
Default Re: How to take gas out of your cylinders. (99blackcivicSi)
Well the car cranks but still doesnt start. So maybe it wasnt just to much gas in there. Now i need to figure out what it is thats wrong.
Old Jun 7, 2004 | 09:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Well the car cranks but still doesnt start. So maybe it wasnt just to much gas in there. Now i need to figure out what it is thats wrong. </TD></TR></TABLE>
did you replace the plugs?
Old Jun 7, 2004 | 09:16 PM
Luserkid's Avatar
There brand spanking new plugs. Gapped to .33 and less then 100 miles on them. Switched them out when i did my turbo. But i didnt switch the wires but the wires are giving me spark. Im starting to think it might be main relay.
Old Jun 7, 2004 | 09:53 PM
If you arn't getting fuel but getting spark it isn't the main relay and vice versa, if your getting both do a compression test might have washed out the rings.
Old Jun 7, 2004 | 10:12 PM
Luserkid's Avatar
I did a compression test before i had this problem. First problem i had was a dead starter but i thought it was something else, so i did a compression test and had nothing. So i got the starter fixed then did another compression test. Now i have 200s across the cylinders with +/- 5psi. So i know my valves are good and so is my piston (guessing since i got such good numbers). But for some reason my car wont start. It would turn over and over but not start. Im going crazy trying to figure out what the **** is wrong and since i work so much i cant really spend that much time on the car. Man its been 3 weeks that i havent driven my car and its driving me ******* crazy
Also im pretty sure im getting fuel and spark. But its not starting
Old Jun 7, 2004 | 10:41 PM
RustyDX's Avatar
How old is your distributor? It could be a worn dizzy cap and rotor. I had a similar problem where car would turn over but wouldn't start, so I replaced cap and rotor and no problems since. Still running same OEM ignition wires that came with the car(1994). It could also be something else with the dizzy. It could be worth a shot.
Old Jun 8, 2004 | 06:29 AM
Luserkid's Avatar
Default Re: How to take gas out of your cylinders. (RustyDX)
You know what, i was having problems with my dizzy before throwing shitty *** codes when nothing was wrong. Pissed me the **** off. Maybe thats it. Ill give it a try, any other ideas? TIA!
lsvtechatch92
Nov 1, 2006 06:46 AM
menappi
33
Jul 11, 2006 10:29 AM
Vroinshk06
Nov 18, 2005 05:12 PM
sik_sol
Apr 7, 2005 07:14 PM
hypa
Feb 17, 2004 09:23 AM
