Best head gasket for d1616?
Old Nov 12, 2001 | 12:49 PM
Shea-bird's Avatar
New User
Default Best head gasket for d1616?
I need a new head gasket so I figure I might as well up the compression a bit while I'm at it who makes the best head gasket for the si engine? it does not necissarily have to raise comp. just a good aftermarker HG(or oem if it's the best). Thanks, shea.
Old Nov 12, 2001 | 12:51 PM
motorpimp's Avatar
Default Re: Best head gasket for d1616? (Shea-bird)
I assume you mean the 88-91 motors .Honda makes the best headgasket short of o-ringing the head. They have changed the headgasket from the old composite style to the MLS new type.Its a real good race piece.
Old Nov 12, 2001 | 01:35 PM
fixhondas's Avatar
Default Re: Best head gasket for d1616? (motorpimp)
You can use a Y7 gasket- it is half as thick as the new metal A6 gasket. @.62mm and A6 metal is @1.14mm. Be sure to use new headbolts.
Old Nov 12, 2001 | 02:22 PM
D-Man's Avatar
The Best Head Gasket is a Honda Head Gasket
enlque
May 21, 2011 06:25 PM
T--Rex
Oct 20, 2004 08:17 PM
USDM 4G VTEC
10
Nov 11, 2002 09:09 AM
