Z6 swap into 91 crx dx, found a extra connector..... help pleassse
so i have my z6 in my shop with the stock wirring harness on it, and im gona be using my crx harness. and i was looking at the z6, and on the rear pass. corner of the block there is the collent chamber and on the z6 theres a 2 wirre connector that plugs into coolent chamber, and on the stock harness for my crx there isnt a plug for that... im gona be using my p28 that came with the z6, so wut am i spose to do with that? thanks soo much for ur help..
Tyler
Tyler
Im pretty sure thats a temp sensor...go to ur local honda shop they should have z6 harnesses laying around and u should be able to get the senor for a few bucks...and wire it into ur harness like everything else...
The Z6 uses 2 sensors....one for coolant temperature, and the second for radiator fan activation. I believe the one in the thermostat housing is for temperature and the second one is located near there that controls the fan. Seems like the fan control one uses a black and a green/white (maybe, not 100% sure) wire....all it does is supply ground for the ran relay once the sensor hits a certain temp.
Hope this helps.
Hope this helps.
phatrick2332
16
Sep 4, 2003 07:48 PM
