what trannys will bolt up ?
i have a 90 civic si with a d16y8 swap. i want a new tranny. i need one bad its orginal like a 160,000 and starting to grind. what trannys from what civics and integras will bolt in to my car with my swap? also what has nice close ratioed gears too? i know some of you honda heads know this. i tried to search and couldnt find what i need to know.
thanks
thanks
All D series trannys will mount up to D series motor...same with B, H and K Series from what I've ready. The D16 SI Transmission is your best pick imo.
Like the others guys said, all D series trannys bolt up. The easiest and best option would be finding a CRX/Civic Si tranny, or maybe search a little more and find a ZC tranny.
Or you could do a Si/ZC combo, with gears from both.
More info about D series trannys and ratios:
http://www.knology.net/~jedikl...s.htm
http://www.thezcr.com/html/tranny.php
any 88-00 D series tranny will bolt
the problem is the 88's one will need a new clutch and flywheel
the 89-91 ones will bolt to the car without problems
the 92-00 ones will need the cable to hyrdo caonversion since ur car is a cable and thos trannies are a hydraulics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">any 88-00 D series tranny will bolt
the 92-00 ones will need the cable to hyrdo caonversion since ur car is a cable and thos trannies are a hydraulics</TD></TR></TABLE>
which hasnt been done and documented yet, but im sure its possible...
Run Away
Dec 19, 2006 05:29 PM
I Gotta Question
Dec 17, 2002 03:22 PM
