Got my 62404 cams in today!!
Ok its a b18b1 with stock pistons, got all the bolt ons, cam gears, fpr and gen1 S-AFC. Mild port with 5 angle job and milled 20 thou. Cpu is chipped so that the rev limit is 8500 but I wont push it much past 7k rpm's anyway. So far i've found the idle is really good even without tuning the AFC it idles. If I lower the fuel at 800 rpm it gets even better. It really pulls after 4000rpm and the sound is pretty impressive as well. I'm going to try and make a short video soon so people can see that these cams idle pretty good. Won't even stall with the A/C on. The valve setting is .006 in and .008 ex for these cams so the ticking is very loud but you can't hear it over the engine once you punch it. I've also noticed that the brake feels a little harder because there is less vacuum but it stops the same its not at all bad. I'll keep you updated, hopefully ill hit a dyno soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrx »</TD></TR><TR><TD CLASS="quote">YEA, go hit the dyno, All-Motor b18b hmm.....
, not to dis you, but i don't think people got good results doing all motor on a b18b</TD></TR></TABLE> bah https://honda-tech.com/zerothread?id=818820
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra »</TD></TR><TR><TD CLASS="quote"> bah https://honda-tech.com/zerothread?id=818820
exactly
</TD></TR></TABLE>exactly
164.5hp ::rolls eyes::
</TD></TR></TABLE>164.5hp ::rolls eyes::
haha thats 164 hp around 6500 rpm.Thats ******* amazing.Remember a itr makes its whoping 170 hp at 8k.So with his head flowing good and good enough bottom end too handle 8k.I bet you could see 180 hp with those cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh4db536 »</TD></TR><TR><TD CLASS="quote">Dont forget about the all important gearing!
something a lot of the nonvtecs forget about
Nothing a b16 tranny can't solve
</TD></TR></TABLE>Nothing a b16 tranny can't solve
I just got mine put in on Friday. Similar set-up, all bolt-ons but I haven't had my head milled.
It idles fine, i have the fuel pressure set at 43psi, and set the afc to like -23 at idle and it's almost like stock.
it ticks pretty loud, louder than before, but not all that bad. It's reall sluggish before 2000rpm, ok after that and really starts going after 4000rpms. And I totally feel a mid-range increase from like 2500-4000.
It's going to be tuned after work today.
p.s. I have to say the bad idle for the 404's has been blown WAAY out of proportion. They DO NOT sound like a harley, they do not stall, they're absolutely fine. Has me wondering qhy I didn't get the 405's.
quote "p.s. I have to say the bad idle for the 404's has been blown WAAY out of proportion. They DO NOT sound like a harley, they do not stall, they're absolutely fine. Has me wondering qhy I didn't get the 405's. "
I agree on that one, if its not running right it wasn't installed right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2chron4u »</TD></TR><TR><TD CLASS="quote">i had mine tuned yesterday, with my fpr at 44psi i had to lean out to -26 to -32 at 1000rpm to be around 14.7 a/f ratio at idle.</TD></TR></TABLE>
44 psi with vacuum?
44 psi with vacuum?
Nice, post up a chart after you get it tuned. I've always liked the 404's but I never heard anything about the brake issues. I would suggest maybe a 2 layer headgasket and a small mill on the head to get you up to 9.8:1. The loss in cranking pressure isn't that much with these cams, but 9.2:1 is far from ideal.
I had mine installed and tuned with stock CR, just a temnporary thing till I can afford the headwork.
Hit 137whp on a dynapack, 104ft-lbs, before the cams I hit 128whp/124ft-lbs on a dynojet, BlueTeg had 152on a dynojet and hit 135on a dynapack, so I think I'm probably around 155whp or so on a dynojet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DC4 »</TD></TR><TR><TD CLASS="quote">Whats the going price on these 404s?</TD></TR></TABLE>
about 400 for new cams, and about 300 for the springs/retainers youll need
