Any one know air pressure setting for Falken Zeix 512 15 inch tires.
Old Jun 6, 2004 | 12:50 PM
First Honda 1976's Avatar
Default Any one know air pressure setting for Falken Zeix 512 15 inch tires.
Any one know the air pressure setting for Falken Zeix 512 15 inch tires . They say high pressure on sidewall , i went to the Falken website and got no pressure info. Any Help from Tire People or someone running them or in the know. THANKS
Old Jun 6, 2004 | 12:53 PM
jdmtheory.com's Avatar
we are j's tunning car maniax!
From: New Used Japanese OEM Aftermarket Parts, San Francisco, USA
Default Re: Any one know air pressure setting for Falken Zeix 512 15 inch tires. (First Honda 1976)
It is on your door jamb.
No tire manufacturer will tell you what psi you should have in your tires.
That is the job of the car manufacturer.
Old Jun 6, 2004 | 01:01 PM
Default Re: Any one know air pressure setting for Falken Zeix 512 15 inch tires. (js auto create)
The Label on the Tire Sidewall says 51 psi MAX , and the Car says 35 psi Tire Pressure . I was thrown by the high pressure on the Sidewall . I guess i will run the pressure on the door label . Thanks
Old Jun 6, 2004 | 08:45 PM
iam7head's Avatar
the door jam/manual spec is for OEM tires only.
if it's 50psi max, go lower like 5 psi.
Old Jun 7, 2004 | 12:26 AM
IVI's Avatar
IVI
Default Re: Any one know air pressure setting for Falken Zeix 512 15 inch tires. (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">the door jam/manual spec is for OEM tires only.
false.
the door jam spec is for tire to weight info
the max tire on the sidewall of a tire is the maximum pressure the tire can hold. it doesnt mean thats the pressure you should put in.
i work at a tire shop, and for hondas acuras i put in 32 psi.
32 is good enough for your application.
and btw i have the same tires, 205 50 15 falkens on my car, i have them at 29.
Old Jun 7, 2004 | 05:33 AM
Default Re: Any one know air pressure setting for Falken Zeix 512 15 inch tires. (IVI)
Thanks i will keep them at 30 or 32 psi depending on how the ride feels . How do you like your Falkens .
Old Jun 7, 2004 | 10:19 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">
false.
what is the psi have to do with acura and honda? so if i swap the rims and tires to a toyota my psi is off?
where you work at and are you ASE cerf.?
Old Jun 7, 2004 | 12:40 PM
IVI's Avatar
IVI
where you work at and are you ASE cerf.?</TD></TR></TABLE>
well hondas / acuras i usually put 32
toyotas 32, toyota trucks 35
fords 32-35 depends.
lincolns, 34
the list goes on. i can continue if you want.
i work at sears auto, and yes im ase certified in brakes.
Old Jun 7, 2004 | 12:41 PM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by First Honda 1976 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks i will keep them at 30 or 32 psi depending on how the ride feels . How do you like your Falkens . </TD></TR></TABLE>
i like them, theyre a decent tire. i wouldve liked the michelins, but theyre just too expensive.
i got mine for a very good deal tho. i got them for 30 dollars a tire.
pricematching is your friend.
Old Jun 7, 2004 | 04:52 PM
I payed $50.00 each with shipping at Discount tire Direct . com I like your deal better . I had a Michelin Sport tire from Sears Auto on the car . I think only the Bridgestone Potenza tire comes close to the Falken Zeix 512 and there almost double the price. Thanks for the Information big help .
Old Jun 7, 2004 | 09:45 PM
The ZIEX 512's are one of the best all-season performance tire. I've had 3 sets of these each lasted at least 45k miles and I will keep using them until they come out with a better technology. It is also one of the few tires that are made & actually being used in Japan.
For tire psi you should really refer to the door jamb for the best possible ride. You can adjust the tire pressure depending on how soft or stiff you want it to ride but this might affect premature tire wear. If you upgraded your wheels +1 or +2 you should definitely adjust your tire pressure to a higher psi for better handling.
The MAX psi on the tire indicates the maximum load each tire can support with that air pressure.
Old Jun 7, 2004 | 09:48 PM
Drive with this much psi and notice how your tires wear on the center.
Old Jun 7, 2004 | 10:04 PM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by js auto create &raquo;</TD></TR><TR><TD CLASS="quote">
Drive with this much psi and notice how your tires wear on the center. </TD></TR></TABLE>
under inflate them and youll wear them from the inside of the tire too where you cant see.
check air pressure regularly and rotate your tires for best performance and longevity out of your tires
Old Jun 8, 2004 | 07:08 AM
Thanks- JS auto Create , I + oned the tire and wheel package so i will probably have to modify the stock PSI by a few Pounds . I can't wait to run the tire on the car and hope to get 50000 miles or so wear , i am a freak for Tire Rotation and checking air pressures. I just put new Bilstein HD shocks and H&R Sport springs on the car , and i am putting a set of Suspesion Teqniques Sway Bars on this month . With the Falkens, the handling and control should be much improved .
grpape
16
May 14, 2009 10:24 AM
Lithel
Feb 26, 2008 02:38 PM
fastjimmy
Nov 8, 2007 10:14 AM
Ash81
Sep 19, 2006 10:43 PM
phoshizzle88
Oct 14, 2005 06:53 PM
