need some gsr guys to check my 1/8 times
Old Jun 6, 2004 | 12:06 PM
sp00led's Avatar
Default need someone to check my 1/8 times
Took my teg out to the track sat. nigth and was able to get in 3 runs. Keep in mind this is my second time to the strip so im not very experienced with anaylizing my times so please fill me in. I was car #51. Temp 65F. The only mods I have are intake(AEM CAI) and exhaust (Greddy EVO2). Stock suspention w/ 17" wheels, 205/40 Kumho Ecsta. Sorry can't get it to look any better once posted times get squeezed together.
1) First run was with a passanger, sucked was distracted and slow as **** off the line. Got beat by a older civic :\
LEFT RIGHT
Car #29 Car #51
R/T .241 R/T .303
60' 2.253 60' 2.693
330 6.383 330 7.278
1/8 9.802 1/8 10.874
MPH 71.07 MPH 69.36
Left 1st 1.1345
2) This run i gave it lot more gas but car lost traction and power some because front end was hopin.
LEFT RIGHT
Car #51 Car #58
R/T .548 R/T .227
60' 2.479 60' 2.626
330 6.931 330 6.952
1/8 10.454 1/8 10.410
MPH 69.94 MPH 72.65
Right 1st .3655
3) This was definitly my best run off the line. Only a little chirp, felt smooth and pulled hard through 1st. This run was against a eclipse spider gs-t not sure what mods if any. *Not sure how my time and mph was better the eclipse won I thought by a little bit. Someone explain*
LEFT RIGHT
Car #31 Car #51
R/T .454 R/T .751
60' 2.554 60' 2.436
330 6.841 330 6.840
1/8 10.392 1/8 10.342
MPH 67.82 MPH 70.89
Left 1st .2478
Modified by redeyz at 9:04 PM 6/7/2004
Old Jun 7, 2004 | 12:00 PM
sp00led's Avatar
Default Re: need some gsr guys to check my 1/8 times (redeyz)
no comments?
Old Jun 7, 2004 | 06:20 PM
STREETWERKZ's Avatar
i highly doubt you'll break 9s with that setup..... even with a lot of seat time.
tune that suspension, practice your launches, get better tires .
you MAY be able to get 9.9 with that alone.
SPEED=MONEY
Old Jun 8, 2004 | 12:11 AM
aznsmtboy's Avatar
if it means anything to you, those 1/8 time equal to about high 15's in the 1/4 mile, you need to work on those 60 foot times, you should be able to pull a 2.2 without much problem after some practice, I'd switch to the stockies if you still have them, the 17's are just way too big.
Old Jun 8, 2004 | 02:31 AM
DA6GSR's Avatar
60' times own you. forreal get those down and you will get better.
you can hit 9s with those mods.
deepsouthhybrid
Honda Civic (2006 - 2015)
138
Jan 14, 2016 05:40 PM
Honder07si
22
Sep 20, 2008 03:04 PM
EVIL Hx Coupe
15
Mar 26, 2005 05:16 PM
Stellar1
14
Nov 25, 2003 02:14 PM
brega3
Jun 26, 2003 10:05 AM
