B16 swap
Old Jun 6, 2004 | 12:00 PM
CRXsihatchback's Avatar
Default B16 swap
I own a 89 CRX and am going to swap a B16 into it. I was wondering if any of you knew about how much this would cost. And if there are any good spots in the Sacramento area i could go to.
Old Jun 6, 2004 | 12:05 PM
bseriesboosted's Avatar
Default Re: B16 swap (CRXsihatchback)
first off you need to research and know what your getting in to second use the search button but i'll do my best
youll need
1. motor swap
2.mount kit
3.axles
4.shift linkage
5.rear motor mount bracket
6.gsr throttle cable
plus the little things that you need to replace before starting the motor like plugs wires water pump timing belt just little stuff that can wear out
thats just the begining so know what your doing before hand
I did my swap for just over 2000 doing all the work myself so just read read read before you buy any thing
DOHCturbo
Feb 15, 2012 07:14 PM
mikej94civex
17
Mar 28, 2010 11:56 AM
Libertariat
Jul 19, 2005 07:41 PM
rexizbest
Aug 21, 2004 12:40 AM
