FS: NGK wires for H22, and Greddy Gauges
Old Nov 12, 2001 | 09:32 AM
girlRacer's Avatar
Default FS: NGK wires for H22, and Greddy Gauges
I'm selling the following:
1. NGK "Power Cables" for the H22A Same ones as Spoon Sports sells. These aren't the regular NGK's that you find here in the States, they are the silicone ones available in Japan. They are a perfect fit, and are in perfect condition. They come with the 4 wires from the spark plugs to the distributor. They did not come with a coil wire, so I had one made up, which is also included in the set. Selling for $125 shipped. http://students.washington.edu/sunn/images/ngkwires.jpg
2. Greddy Temp and Oil pressure gauges. These are the 52mm black faced ones. The temp gauge can be used for either oil temp or water temp. These gauges are a full 270 degree sweep and are electrical. You don't need to mess with oil lines in your car and you get a full 270 degree sweep. Also, they are already fitted with BSPT fittings, so you also don't need to mess with convertor adapters either. They are much more plug and play than your typical Autometer gauge. Both for $200 shipped, or $95 shipped for the temp, and $115shipped for the oil pressure gauge.
http://students.washington.edu/sunn/images/gauges.jpg
E-mail me if interested.
mcmmotorsports
Feb 2, 2014 01:50 PM
TurboGSR10
Nov 9, 2006 09:56 AM
IN VTEC
Jun 20, 2004 04:53 PM
