what is a port
what is a port? what exactly do you do on a port?
lookin to do it to my b18 . i drove a teg with a port . and it kicks. so i want it. just need info about porting the head and the intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WEBSTER'S »</TD></TR><TR><TD CLASS="quote">Main Entry: 1port
Pronunciation: 'pOrt, 'port
Function: noun
Etymology: Middle English, from Old English & Old French, from Latin portus -- more at FORD
1 : a place where ships may ride secure from storms : HAVEN
2 a : a harbor town or city where ships may take on or discharge cargo b : AIRPORT
3 : PORT OF ENTRY
Main Entry: 2port
Function: noun
Etymology: Middle English porte, from Middle French, gate, door, from Latin porta passage, gate; akin to Latin portus port
1 chiefly Scottish : GATE
2 a : an opening (as in a valve seat or valve face) for intake or exhaust of a fluid b : the area of opening in a cylinder face of a passageway for the working fluid in an engine; also : such a passageway
3 a : an opening in a vessel's side (as for admitting light or loading cargo) b archaic : the cover for a porthole
4 : a hole in an armored vehicle or fortification through which guns may be fired
5 : a hardware interface by which a computer communicates with another device or system
Main Entry: 3port
Function: noun
Etymology: Middle English, from Middle French, from porter to carry, from Latin portare
1 : the manner of bearing oneself
2 archaic : STATE 3
3 : the position in which a military weapon is carried at the command port arms
to turn or put (a helm) to the left -- used chiefly as a command
the left side of a ship or aircraft looking forward -- called also larboard; compare STARBOARD
a sweet fortified wine of rich taste and aroma made in Portugal; also : a similar wine made elsewhere
Function: abbreviation
portable, portrait
hope this helps.
Function: noun
3 : PORT OF ENTRY
Main Entry: 2port
Function: noun
Main Entry: 3port
Function: noun
2 archaic : STATE 3
portable, portrait
hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by answer703 »</TD></TR><TR><TD CLASS="quote"> i drove a teg with a port . and it kicks.</TD></TR></TABLE>
did it kick u in the face?
Porting is basically just taking the head of your motor and grinding down the intake and exhaust ports into a more agressive, or efficient way. it's done by sharpening the dividers and making the hole bigger to accomodate more flow. Polishing is smoothing the ported job so the flow is much smoother, thus reducing drag and turbulence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlaN. »</TD></TR><TR><TD CLASS="quote">Porting is basically just taking the head of your motor and grinding down the intake and exhaust ports into a more agressive, or efficient way. it's done by sharpening the dividers and making the hole bigger to accomodate more flow. Polishing is smoothing the ported job so the flow is much smoother, thus reducing drag and turbulence.</TD></TR></TABLE>
right on the money...lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by answer703 »</TD></TR><TR><TD CLASS="quote">thank you</TD></TR></TABLE>
you're welcome
you're welcome
IMO its not worth it if you don't do any other work internally. what type of power are you looking for? do you have a b18b1? if you do, I suggest LS turbo, it's fun as **** and reliable if done right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by answer703 »</TD></TR><TR><TD CLASS="quote">what type of internals do you suggest? </TD></TR></TABLE>
do you have an LS? if so I don't suggest any internals. slap a turbo kit on and have fun. i've been in one FULLY BUILT ls before and it was kind of quick, but it was no where near as quick as my boosted teg, plus it rode pretty choppy because of the "lopey" idle..
94vtirozguy
20
May 17, 2007 03:16 PM
FIRST OFF I WANNA THANK VINNY FOR A AMAZING PORT AND POLISH. NO MACHINES HAVE TOUCHED THIS HEAD THIS
GDM S2K
Honda S2000
Jul 31, 2006 06:04 PM
mycvc8u2
20
Sep 29, 2003 01:15 PM
