How long to tune hondata?
Old Jun 5, 2004 | 02:45 PM
red civic standard's Avatar
Default How long to tune hondata?
I am going to HPworks on Tuesday to have my motor tuned by sgt. It is a JDM type R with bolt-ons and mild cams. I have hondata s100 and cam gears to tune.
How long will it take? Just trying to get an idea of how much money this is going to cost.
Old Jun 5, 2004 | 03:39 PM
Suprdave's Avatar
Default Re: How long to tune hondata? (red civic standard)
1-2 Hours Probably...
Old Jun 5, 2004 | 03:49 PM
Default Re: How long to tune hondata? (Suprdave)
I have read some old threads that seem to think that it will take 3-4 hours. But those were all boosted cars.
Old Jun 5, 2004 | 04:22 PM
92TypeR's Avatar
FSAE
Fuel/ignition maps take about 2 hours to get a good full tune. Cam gears take a little longer.
Old Jun 5, 2004 | 06:59 PM
na200whp's Avatar
Default Re: How long to tune hondata? (92TypeR)
his set up is mild but what if is a 2.0lt with 13 to 1 comp and big cams and such. should this cause the tune to take much longer to iron out the driveablity bugs?
Old Jun 5, 2004 | 10:14 PM
Suprdave's Avatar
Steve tunes fast, he knows what hes doing.
Old Jun 5, 2004 | 11:41 PM
obd2gsr's Avatar
what ecu are u using?
Old Jun 6, 2004 | 04:55 AM
IN VTEC's Avatar
The good tuners probably do a lot of extrapolation by interpolating across hand-tuned islands (for AFR's), kind of like playing connect the dots. I'm guessing it's an assumption that can be made and still be within 5% of what the engine needs.
I'm not a good tuner, so I wouldn't know. I spend easily an hour and a half to two hours working on a loading dyno just on the AFR's. Maybe I'm using the loading dyno as too much of a crutch when I could do it just as easily on a dynojet.
Old Jun 6, 2004 | 05:21 AM
Default Re: How long to tune hondata? (obd2gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd2gsr &raquo;</TD></TR><TR><TD CLASS="quote">what ecu are u using?</TD></TR></TABLE>
p28 with hondata s100
Old Jul 25, 2004 | 04:05 PM
jdmturbosol's Avatar
the great words of Torin... "Extrapolate"
Old Aug 8, 2004 | 06:09 PM
GruvyTune's Avatar
New User
Default Re: How long to tune hondata? (jdmturbosol)
yes, i like that word.
Old Aug 8, 2004 | 08:38 PM
99b18's Avatar
Default Re: How long to tune hondata? (GruvyTune)
youll be lookin at a couple hours or so for fuel maps and ignition. but i think it was mentioned already. you may be lookin at a lot of dyno hours to tune the cams. especially if you dont have a cut valve cover.
iperez
Jan 10, 2007 07:28 AM
b18c5 EG
Apr 11, 2006 09:10 AM
RangerDan
Aug 12, 2003 11:55 PM
Jonathan_ED3
Jun 20, 2003 06:10 AM
1abSi
21
Apr 27, 2003 08:24 PM
