Sway Bar Busings Gone Bad
Old Jun 5, 2004 | 01:32 PM
Flux's Avatar
Default Sway Bar Busings Gone Bad
Discovered yesterday that my rear sway bar has a lot of free play within the bushings that have apparently gone bad. It is a 23mm bar and I was using the stock 22mm bushings.
I need to get some replacement bushings ASAP. I know some people have used these: http://www.suspension.com/s.b.bushings.htm and was wondering if these are a good replacement or if there was any feedback on them.
Any other recommendations for 23mm bushings?
Old Jun 5, 2004 | 02:25 PM
B2FiNiTY's Avatar
Default Re: Sway Bar Busings Gone Bad (Flux)
How did you check for play?
Old Jun 5, 2004 | 02:33 PM
Flux's Avatar
Default Re: Sway Bar Busings Gone Bad (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">How did you check for play? </TD></TR></TABLE>
The car was up on a lift and I grabbed the bar and pulled on it and it moved within the bushings... I didn't have to pull it very hard. It was if the opening of the bushings were now too big and there was some free room in there for play...
Old Jun 5, 2004 | 04:18 PM
Cosworth's Avatar
[QUOTE=Flux]It is a 23mm bar and I was using the stock 22mm bushings.
QUOTE]
How did you make the bushing fit? Did you bore out the bushing with a dremel?
Try IM-ing Mike M, R&D or Leo... one of these guys should have OEM JDM 23mm bushing in stock.
96romaEK
Suspension & Brakes
26
Apr 16, 2010 03:25 PM
team_exceed
Apr 11, 2008 08:08 AM
needtoknow
Suspension & Brakes
Nov 27, 2007 06:18 PM
unknown2
Sep 2, 2004 06:29 PM
GreenBean
Feb 26, 2004 01:01 PM
