Lots of parts in VA
Parting out my 91 Integra with lots of parts. int is tan.
#1 Engine, Block - It is a B18A block with PR3 pistons on LS rods with new rings and bearings with ARP rob bolts holding them. Head - a PR3-2 B16A head with Type R cams and stock b16 vavle train. No leaks at all except the oil pan gasket needs to be replaced. 11.6 compression compression tested at 230 230 250 and 230. AEBS manifold with JG tappered 62 mm TB. still in the car. will required you to either buy the whole car or pull the engine out yourself. engine runs good only had about 3000 miles after rebuild, currently on a auto tranny so you know it has not been revved hard. price is negotiable.
#2 Rear Lower Tie bar made by Ben Ogle Sport brand new never installed 50 shipped.
#2 rear upper strut bar, some generic bar, does the job. 20 shipped.
#4 front Neuspeed strut bar, still in good shape very very nice bar will fit CRXs and older civics i believe 80 shipped.
#5 Alpine V12 4x200 rms amp (not sure if i am going to sell it)
#6 ICEMAN Cold air intake. painted to black was blue 70 shipped. very good intake. has a K&n filter on it but it is used.
#7 Jet chipped Auto ecu for non-obd integras. increased timing and fule.
#8 1 mildly ported LS head for turbo with brand new valve seals, new exhaust valve guides and 3 angle vavle job. one of the cam holder hoels needs to be tapped. 150 shipped.
#9 stock LS head with a few missing parts but overall in good condition, was used on my car. head is shaved approx 30. 80 shipped.
#10 Crower LS dual vavle springs in great condition 80 shipped.
#11 single a-pillar guage pod has squre hole cut at the bottom, i had a fog light switch in it. 15 shipped.
#12 one piece head lights, both has a lil tiny crack but it is not craked all the way through. I bought these from someone thinking that i was going to fix my car back up but decided not to. 100 shipped for both.
#13 RSR catback exhaust, the front where it connect to the cat had been cut and welded to a 3 inch cat and also the rear tip have felled off before but had that also welded too. everything is good now and no leaks. some scratches on the tip but overall the exahust still in good shape and sounds great. not sure how i can ship this so preferred this to be picked up for 200 without the cat and 250 with the cat.. you'll have to get it off the car.. =o im done working on the car hehe.
#14 Set of silver AEM cam gears, they need new bolts but other than that they are in great shape. 80 shipped.
I am at work right now and can't think of anything else but im sure there are alot of other things. I will post them when i remember them.
Any piece i will sell just let me know what u want, I can take pictures of whatever u want too. I also have a lot of bulbs left, all sorts of bulbs so if you are interested in those let me know too.
4 old school SE-R wheels painted black, in ok shape but they are not worth much however the tires are in great shape. only 3000 miles on them Yokohama AVids 14/195 all 4 are basically brand new. if you want these i need 4 steelies with tires so i can roll the car when i sell it to the junkyard. if u got the steelies 150 for all 4.
blink1682
Feb 16, 2006 06:42 AM
Arsenal
Sep 30, 2002 08:45 AM
2kGSboi
Sep 11, 2001 12:52 AM
