need help changing manual tran fluid
this is my first manual car and i need to change the tran fluid but need some help. i have a 1995 accord. ok, looking at the tranny from passenger side i see three hex bolts; one way on top just a little bit below the inner fender, the next one is about an inch below the top one, and the third one is all the way down by where the axle is. is the one down by the axle the draining screw? i looked underneath in the front of the tranny; not on the side where the other three screws are, is a regular bolt probably size 14. what is that bolt for? please help... thank you... pictures will be greatly appreciated.
Modified by wblakes at 10:50 PM 6/5/2004
the 2 square bolts next to the fender are not for changing the fluid, the one under the axel is the drain and the 14mm is the fill hole. just did mine this weekend.
PrettyFastRide
Jan 7, 2007 07:46 PM
