17" Volk TE 37's - What offset, and what tires are good?
Old Nov 12, 2001 | 06:58 AM
White Dragon's Avatar
Default 17" Volk TE 37's - What offset, and what tires are good?
What offset do I need for the rims, and what size tires? Also, what's a good tire?
Old Nov 12, 2001 | 07:28 AM
austrian type-R's Avatar
Default Re: 17" Volk TE 37's - What offset, and what tires are good? (White Dragon)
For the 17x7 you need an offset of minimum 30 or go up to 50
For the 17x7.5 you need an offset of minimum. 35. ...or you also can go up to 45
For the 17x8 you need an offset of 40 - minor fender works maybe necessary.
[Modified by austrian ITR, 8:29 AM 11/12/2001]
Old Nov 12, 2001 | 07:55 AM
koy's Avatar
koy
New User
17x7.5,+40,205/40/17 per Rays/Volk chart
Wai's Avatar
Wai
ProFunction/GT Motoring
Hey Wes, I know that Mattj (DropSpeed) is running 17" SSR Competition for the street. IM him and I'm sure he would be willing to tell you with no charge.
Old Nov 12, 2001 | 08:14 AM
Thrashin's Avatar
if you end up getting the 17's go with some yok. a520's
Old Nov 12, 2001 | 11:01 AM
Benjamin Tang's Avatar
Default Re: 17" Volk TE 37's - What offset, and what tires are good? (jdmeg6)
been there, done that.... will never do it again
Old Nov 12, 2001 | 02:01 PM
Default Re: 17" Volk TE 37's - What offset, and what tires are good? (Benjamin Tang)
Could you please elaborate?
Old Nov 12, 2001 | 02:32 PM
17x7.5+40 215/40/17. rubbed all over the place front and rear, ride was harsh, couldn't get a good launch out of 40-series tire. tried to induce negative camber in the rear and positive in the front to stop the rubbing, and even rolled the fenders, but all i did was mess up the handling. i tried to go 205, but everyone warned me there wouldn't be enough rubber to prevent bending the wheels if i did. finally i gave up and went to these 16" evos... much happier now
Old Nov 13, 2001 | 01:09 AM
RMR's Avatar
RMR
New User
Wes, we have the Volk TE37 17 X 7.5 with +40 offset. 205/40 X 17 fits no problem and won't bend the wheel, unless you hit a pothole or curb.. We have tried the 215/40 X 17, it rubbed in the back fender lip only, fronts were okay, but 205/40 were a better fit.
These 17 inch wheels are good for the street. On the track, we use the 15 inch TE37 since it is quicker than the 17 inch. If your getting wheels for the track, go with the 15 inch.
If your looking for street tires, I would get the Dunlop Sport SP8000. For Track tires 205/50 X 15, I would go with the old Kumho V700 Victoracer or the Hoosier RS03 for quicker lap times.
[Modified by RMR, 3:38 AM 11/13/2001]
Old Nov 13, 2001 | 05:05 AM
Dipshit Dan's Avatar
Default Re: 17" Volk TE 37's - What offset, and what tires are good? (RMR)
If going with 17X7.5 I recommend the +48mm offset.
Old Nov 13, 2001 | 07:07 AM
Default Re: 17" Volk TE 37's - What offset, and what tires are good? (God)
after my experience i'm thinking +48 with a 7.5" wide wheel might cause rubbing on the inside up front?
Old Nov 13, 2001 | 08:14 AM
Depends but with 3mm spacers no problem.
Old Nov 13, 2001 | 08:59 AM
will 3mm spacers require extended wheel studs?
Old Nov 13, 2001 | 10:40 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
15x6.5" rocks your socks.
Old Nov 13, 2001 | 11:43 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: 17" Volk TE 37's - What offset, and what tires are good? (SkyeC)
Skye: Your car is looking good
Even better than last time I saw it.. with ripples and dents on the left side!
Old Nov 14, 2001 | 12:34 PM
This would be my concern also... anyone have this set-up?
Wes
MNsnowdaboy
Aug 11, 2006 07:27 PM
Integra21
Jun 23, 2005 09:18 PM
cokinut
Mar 30, 2003 04:03 PM
Hondaaccordvtec
Jan 25, 2003 09:48 PM
Doogie Howser
Jun 24, 2002 05:34 AM
