WRITE UP: Cleaning those pestky foggy headlights (56k, just be patient)
Old Jun 5, 2004 | 10:27 AM
DizDitto's Avatar
Default WRITE UP: Cleaning those pestky foggy headlights (56k, just be patient)
Yesterday I finally got a chance to take a real good look at my headlights and found that they had a disturbing foggy layer of who knows on it. As you can see:
Some before pixors of only the passenger headlight because I had already started on the driver side when I decided to take pix to do this write up...
After putting some elbow grease in with a fine grit sand paper (preferrabily 1500 grit) and some water...Oh, these are the driver side headlights after the first time around with the wetsanding:
And after the second time around the headlights came out looking as such...(Recommended to wetsand for a second time to make sure all foggy residue is off)
Finally, when you have put so much effort in sanding the foggy stuff off your lamps you get to give them that shine you have always wanted your headlights to look!
With these waxing products I have given them the shine they have in the following pixors...
That's all folkz! Questions = welcome!
Modified by DizDitto at 8:03 PM 6/5/2004
Old Jun 5, 2004 | 10:29 AM
PhantomSTi's Avatar
Default Re: WRITE UP: Cleaning those pestky foggy headlights (DizDitto)
X's
Old Jun 5, 2004 | 10:30 AM
integra-modder's Avatar
And one of the passenger side after the first run:
Take the "&caption=jun05065"off of the picture addresses
Old Jun 5, 2004 | 11:05 AM
Gerbilo's Avatar
Default Re: WRITE UP: Cleaning those pestky foggy headlights (integra-modder)
not bad...
did you take your bumper off merely to do this?
Old Jun 5, 2004 | 11:07 AM
DizDitto's Avatar
Default Re: WRITE UP: Cleaning those pestky foggy headlights (Gerbilo)
Yeahz, it helps because the frog eyes need to be exposed all the way and plus I wanted to see how my new OEM+lip would look on it
Old Jun 5, 2004 | 11:36 AM
SloGizzer's Avatar
I used the Eagle One Never-Dull on my headlights, works like a charm!!
Old Jun 5, 2004 | 11:56 AM
B2FiNiTY's Avatar
Default Re: WRITE UP: Cleaning those pestky foggy headlights (SloGizzer)
just like new!
Old Jun 5, 2004 | 11:58 AM
frenchy's Avatar
Default Re: WRITE UP: Cleaning those pestky foggy headlights (B2FiNiTY)
i went to auto zone and got a $4 bottle of plastic cleaner - looks better than new
Old Jun 5, 2004 | 02:03 PM
au-gsr's Avatar
Default Re: WRITE UP: Cleaning those pestky foggy headlights (frenchy)
try using meguiars platix polish, a lot safer and you don't have to worry about wet sanding and all the time it wil take.
Old Jun 5, 2004 | 02:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frenchy &raquo;</TD></TR><TR><TD CLASS="quote">i went to auto zone and got a $4 bottle of plastic cleaner - looks better than new</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frenchy &raquo;</TD></TR><TR><TD CLASS="quote">i went to auto zone and got a $4 bottle of plastic cleaner - looks better than new</TD></TR></TABLE>
what do you have to do?
import-tooner
Feb 23, 2010 06:43 AM
InTeNsE805vp
Jul 8, 2008 01:03 PM
cimo463
Apr 2, 2008 01:18 PM
SIcivicHATCH
Jan 13, 2005 05:57 AM
Kellindal
Oct 21, 2002 11:43 AM
