Had problems w/ AutoZone axles? Maybe this is why....
Old Jun 5, 2004 | 10:22 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Had problems w/ AutoZone axles? Maybe this is why....
I just took my 2 new (rebuilt) AutoZone axles out of the box, and just happened to measure their length and compare to the spec listed in the Helms. They are supposed to be 475-480mm, and my passenger side axle measured over 20mm too short, and the driver side one was about 10mm too short. That means if I were to install them, the inner joint would have to extend out, and would probably extend out too far. If I tried something like a drag launch, they would probably break.
So now it's time to return these and check out NAPA's axles. Good thing I haven't installed them yet
Old Jun 5, 2004 | 11:32 AM
JDM PRO's Avatar
Default Re: Had problems w/ AutoZone axles? Maybe this is why.... (PatrickGSR94)
i wouldn't buy anything rebuilt from my past experience. Get it from the dealer w/out worries
Old Jun 5, 2004 | 01:15 PM
Xumarius's Avatar
Default Re: Had problems w/ AutoZone axles? Maybe this is why.... (JDM PRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't buy anything rebuilt from my past experience. Get it from the dealer w/out worries </TD></TR></TABLE>
It depends on the product and where you get it from I have a rebuilt starter and a CV joints and after 2 years no problems
Old Jun 5, 2004 | 01:23 PM
jDMJeRk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I just took my 2 new (rebuilt) AutoZone axles out of the box, and just happened to measure their length and compare to the spec listed in the Helms. They are supposed to be 475-480mm, and my passenger side axle measured over 20mm too short, and the driver side one was about 10mm too short. That means if I were to install them, the inner joint would have to extend out, and would probably extend out too far. If I tried something like a drag launch, they would probably break.
So now it's time to return these and check out NAPA's axles. Good thing I haven't installed them yet </TD></TR></TABLE>
good catch and reserch pat.....
Old Jun 5, 2004 | 01:35 PM
Axle's Avatar
Default Re:
I got both of mine from NAPA because I trust them long before I trust Auto Zone, and they were cheaper too with the core exchange and all.
Old Jun 5, 2004 | 02:25 PM
PissedoffGS-R's Avatar
Default Re: Re: (Axle)
What brand where they? Can you do me a faver and call and ask im very cerious. I just baught one from there after a long search of the company they gp through, i was recomended a specific brand by an acura repair guy and hutned out who had them. IE Autozone.
Old Jun 5, 2004 | 02:35 PM
Community Builder
Alright I got some axles from NAPA, they're the exact same ones that AutoZone sells, same box and same part number and everything. They brought out an axle for each side of the car, and I measured them. The driver side one was fine, but the passenger side one was still too short, and also had some grease on the outisde. So they took that one back and brought out another one, and it appears to be good. Spec calls for the axles to be about 18.75" and both of mine are within about 1/4" of that, so I should be good, since that inner joint moves in and out anyway as the suspension moves.
Old Jun 5, 2004 | 02:52 PM
riceball777's Avatar
i have auto zones life time warantee for there axles
and i seem to break them all the time and maybe this is why
i mean i brake their axles at least a few time a year
Old Jun 6, 2004 | 06:18 AM
Axle's Avatar
I had a similar problem with my Belkin hub bearings when I got them at Auto Zone. When I had NAPA press them in (they're cheaper at Auto Zone, but NAPA's a machine shop), the machinist told me that someone must have messed up at the factory because the bearing I brought him was not a sealed kind and I should get another one. Well, after a little bit of driving around, it turns out that some are sealed and some aren't because I looked into the bin and through several packages, and some are sealed and some aren't, just have to make sure both sides are the sealed ones, even though both carry the same part number for some reason.
Old Jun 6, 2004 | 02:16 PM
gsr415's Avatar
this is why cheap is not always better
Peruviann83
Apr 11, 2007 07:24 AM
BlUeHoOdCiViC99
12
Dec 24, 2005 12:38 PM
sparxx
Mar 19, 2005 04:09 AM
ghettols
Aug 22, 2003 11:57 AM
hybrid901
Jun 3, 2002 11:42 AM
