99-00 Civic si parts and JDM
Old Jun 5, 2004 | 07:38 AM
vtec_r's Avatar
Default 99-00 Civic si parts and JDM
99-00 SI rear sway bar (bar only) $45.
SI b16a2 Flywheel $25.
AEM red alternator under drive pulley with belt new in box never used $35.
AEM cold air intake 99-00 SI (no filter) $75.
99-00 SI front brembo rotors Stock size cross drilled and sloted Easy to change no mod needed they are a direct bolt on replacement $45.
99-00 stock rear disk rotors $25.
CRV steel 15inch rims $45 for all 4
JDM 99 gsr gauge cluster 180 klm 8000 red line $45.
also
eibach/aem rear sway
This is a very rare item It was originaly Designed for the Eibach/AEM 99 civic SI that was to be sold at dealers. If you have the '99 CAR and DRIVER mag with the write up on the civic They rave about the inproved handeling.It is adjustable by having two holes for the endlinks to bolt to on the end of the bar.So that will alow you to shorten the bar for a firmer ride. It is brand new and has polly bushings. It is 19mm and is a direct bolt on for the the 99-00 si But I have end links and bracket if you would want to bolt it on any 99-00 civic. The bar will provide a very neutral handeling with out having to reinforce the lower frame.
200 with end links and brackets and bushings and all the bolts you would need to install on any 99-00 civic
or
175 for the bar and bushings alone
I will email pics email me at Travis.walker@gulfstream.com
Ebay ref. vtectw
Modified by vtec_r at 5:58 AM 6/6/2004
Old Jun 6, 2004 | 01:59 AM
vtec_r's Avatar
Default Re: 99-00 Civic si parts and JDM (vtec_r)
ttt..
Old Jun 6, 2004 | 06:22 AM
heel_touge's Avatar
you have IM
Old Jun 6, 2004 | 11:03 AM
vtec_r's Avatar
Default Re: 99-00 Civic si parts and JDM (1slowcivic)
now you have im
Old Jun 8, 2004 | 02:31 PM
vtec_r's Avatar
up for day
Old Jun 12, 2004 | 04:39 AM
vtec_r's Avatar
Old Jun 14, 2004 | 07:55 AM
vtec_r's Avatar
hcridesi
Mid-Atlantic (Sales)
Nov 27, 2009 01:05 PM
vtec_r
Jan 9, 2005 04:02 AM
vtec_r
Sep 18, 2004 07:27 AM
flyrice
Sep 1, 2004 04:15 PM
