FITV , does obd1 ECU look for it?
Old Jun 5, 2004 | 03:18 AM
DOMKID's Avatar
Default FITV , does obd1 ECU look for it?
Hello. Maybe you guys can help me out here. I am running an obd2 b18b with obd2 TB(no FITV, just IAC). However, when i swapped in an obd1 ECU using a conversion harness i am getting a surging idle from 1k-1.5k. Does the obd1 ECU looks for a FITV? if so, is there anyway to bypass it or get my idle back to normal. Or am i going to have to get an obd1 TB?
thanks!
Old Jun 5, 2004 | 04:30 AM
EE_Chris's Avatar
Default Re: FITV , does obd1 ECU look for it? (Dominican_Kid)
The FITV is an all-mechanical valve....it has no electrical connection with the ECU.
Which OBD1 ECU did you plug in?
Old Jun 5, 2004 | 11:52 AM
DOMKID's Avatar
Default Re: FITV , does obd1 ECU look for it? (EE_Chris)
obd1 p75.
Old Feb 21, 2006 | 02:02 PM
type Gendy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">The FITV is an all-mechanical valve....it has no electrical connection with the ECU.
Which OBD1 ECU did you plug in?</TD></TR></TABLE>
so how can u compensate cold starts on an obd2 motor (no fitv) and obd1 ecu ( no cold start / iacv control)
Old Feb 21, 2006 | 06:38 PM
v4lu3s's Avatar
RTFM
the obd1 ecu does have cold start adjustment though....just nto as good as obd2
Old Feb 22, 2006 | 03:52 PM
EE_Chris's Avatar
Default Re: FITV , does obd1 ECU look for it? (type Gendy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy &raquo;</TD></TR><TR><TD CLASS="quote">so how can u compensate cold starts on an obd2 motor (no fitv) and obd1 ecu ( no cold start / iacv control)</TD></TR></TABLE>
OBD2 motors use an IACV for idle control....that's it.
As for OBDI, if you disable the FITV by screwing the ring up, your cold idle will suffer some but it still uses an IACV for idle control.
Ek9_Cuhzz
Northwest (Sales)
Jul 15, 2010 12:07 PM
Jap_Spec_Imports
Aug 10, 2009 07:11 PM
3rdgencrx
12
Feb 14, 2007 05:26 PM
2.2 teg
Oct 20, 2005 08:21 AM
xtremecivichb
May 19, 2003 05:07 PM
