88-89 Tach Cluster
Old Jun 5, 2004 | 01:28 AM
EF Two.'s Avatar
Default 88-89 Tach Cluster
Ok my friend let me borrow his cluster from his 89 CRX(its automatic). We put it in my car it doesn't work, we put it back in the CRX it works, back in my car didn't work. I drive a 89 Civic DX standard. Do the automatic gauge cluster not work in a standard car? I heard you can get a cluster from an auto 88-89 4 door and it would work, is this true? The CRX one didn't work what would make that one work? Need help. Which tach clusters work? (yes I did search)
Old Jun 5, 2004 | 01:35 AM
CyniKal.Mindset's Avatar
Default Re: 88-89 Tach Cluster (H-Spec)
it shoulda worked...did u make sure everything was plugged in proper? what didnt work on the cluster? lights, speedo, tach what?
Old Jun 5, 2004 | 01:56 AM
EF Two.'s Avatar
Default Re: 88-89 Tach Cluster (CyniKal.Mindset)
Speedo worked, but nothing else did.
Old Jun 5, 2004 | 02:07 PM
EF Two.'s Avatar
Anyone?
Old Jun 5, 2004 | 02:13 PM
dcvt16's Avatar
do a search and you will find the tread...the 89 civic and 89 crx gage cluster wiring are different. i just got done doing the swap in my 89 civic.
Old Jun 5, 2004 | 02:17 PM
EF Two.'s Avatar
Default Re: 88-89 Tach Cluster (dcvt16)
So pretty much just look for a Civic cluster.
Old Jun 6, 2004 | 11:04 PM
dcvt16's Avatar
naw, if you can find the post on it, to know where the wires go ,its very easy to swap the pins and extend one wire. ill look for the post also.
here you can use this for pin placement this is what i used. i only used the info for the 89 https://honda-tech.com/zerothread?id=709958
Old Jun 7, 2004 | 08:28 AM
T-Mo's Avatar
he is talking about putting a auto cluster (same years) into his CRX w/ a 5 speed. It should work. I have a '90 auto cluster w/ tach in my '91 hatch w/ manual tranny. It works fine. Although I had to get used to the 'prdn**' on the cluster. Now I don't even notice its there.
Old Jun 7, 2004 | 03:00 PM
dcvt16's Avatar
Default Re: (T-Mo)
he drives an 89 civic and the cluster is from an 89 crx and they are different. auto or not he still has to change the pins to make it work. i know exactly what your saying 90-91 are all the same. 89 civic and crx differ. i beleive it has to do w/ the seat belts in the door ie: newer style wiring.
the auto works the same as non auto.
Old Jun 8, 2004 | 08:31 PM
ghonaherpalitis's Avatar
so from most replies are saying........ the clusters should be a "Plug and play" sort of deal right? that's if you keep within the 88/89 and 90/91 range...
I tried switching to a cluster with a tach 'cause I didn't have one before - should this matter even though my car is 91 and the cluster is 91? The tach isn't working, everything else is.
Old Jun 22, 2004 | 06:09 PM
EF Two.'s Avatar
Default Re: (Jockette)
well the 88-89 the Civic and CRX wiring is different. Don't know about the 90-91...
BIGef
Mar 23, 2012 06:20 PM
EF Two.
31
Feb 23, 2005 12:15 PM
