HELP: possible fluid leak from my power steering pump..... what to do??
Old Jun 4, 2004 | 10:24 PM
PaChiLa Leader's Avatar
Default HELP: possible fluid leak from my power steering pump..... what to do??
i refuelled and top my power steering fluid about 2 months ago and then noticed there was some kind of fluid leaking from my oil pan while i was doing oil change this afternoon. i dump my oil out to see if it's my oil but it wasn't. i looked around then found out that my ps fluid is below the low level again.... i have no idea what's causing this to happen. can someone help me plz and what do i have to do to make it stop leaking out
thank you
Old Jun 5, 2004 | 06:54 AM
kchungb17a's Avatar
Default Re: HELP: possible fluid leak from my power steering pump..... what to do?? (PaChiLa Leader)
PS systems like to leak at the pump. Is the bottom of the pump wet with fluid? If so, don't despair, the pump can be resealed with an O-ring kit from the dealer, provided you still have the OEM pump. And it's very easy to do. 2nd most likely spot is the high pressure line (the big one that goes from the top of the pump and mounts to the valve cover).
Old Jun 5, 2004 | 06:58 AM
IN VTEC's Avatar
It's probably leaking from the o-ring at the pump's inlet port at the front of the pump. I'm not sure how to fix it either. I've replaced the o-ring and it still leaks.
It could also be the draw-through hose that connects to the reservoir line.
Old Jun 5, 2004 | 09:46 AM
Axle's Avatar
Default Re: HELP: possible fluid leak from my power steering pump..... what to do?? (IN VTEC)
Do you use Honda-specific power steering fluid or just the cheapest you can find? By Honda-specific, I don't mean Honda dealership with the Honda brand name on the front at like $5 for a 12 oz bottle, but just fluid that's specifically for Hondas. I know Auto Zone carries one made by Coastal and it says HONDA Power Steering fluid right on it. If you haven't been, this would explain why the o-rings and seals inside the pump have been damaged, because the fluid isn't what's preferred to be in that pump, especially since at one point when the car was new, it had the correct fluid in it.
What I did with mine is I searched around all of the hoses (high pressure, low pressure, and reservoir), steering rack, and pump itself. Once I found that the leak was in the pump itself and that because the previous owner drove it for some time on generic power steering fluid and thus destroyed the o-rings, I bought a remanufactured pump from Auto Zone and called it a day.
Note of warning because this freaked me out yesterday, when you install the new pump and fill the reservoir to the top, after you drive it around the block, it will feel like there's no power steering and you look and the fluid in the reservoir is non-existant. Do not suspect a leak elsewhere just yet, the fluid that you initially poured in has to travel through the rest of the system and lube it up and so you have to add yet another 12 oz bottle to the reservoir and then it will be fine. Coastal brand Honda-specific power steering fluid is a mere $2.49+tax at Auto Zone for a 12oz bottle, buy two.
Old Jun 5, 2004 | 11:06 AM
IN VTEC's Avatar
Default Re: HELP: possible fluid leak from my power steering pump..... what to do?? (Axle)
I've always used Honda PS fluid.
The leak occurred on the original '95 pump and then also on the '98 pump I switched to a couple years ago. It leaks less, but it's nowhere near being cured.
smcdonaldaz
Acura TSX
Dec 10, 2019 01:21 PM
murrellington
May 8, 2014 03:30 PM
cmarlow4
Apr 15, 2013 06:04 PM
DeDonDeRosa
Dec 10, 2005 10:25 AM
earthworm
Jun 2, 2005 08:37 PM
