hatch rattle
Loosen big azz phillips screws and move the chrome latch hook around until it closes tight. If that doesn't work take the shim(s) out from underneath it.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccosentino »</TD></TR><TR><TD CLASS="quote">my rattles too after i installed new sturts.did that happen to you too?</TD></TR></TABLE>
NO, did you tighten the strut bolts to torque?
Just remove the shim from under the striker.
It's NOT hard to do, and it looks better than those ghetto methods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kur0ryu »</TD></TR><TR><TD CLASS="quote">mine has a squeaky rattle, it seems to quiet after applying wd40 to the rubber bumper parts.</TD></TR></TABLE>
Try adjusting the little rubber bumpers on the inside edge of each side of the hatch.
Turn them in or out as need to get rid of the rattle.
Open the hatch, lift it all the way. look along the inner surface you'll see one rubber bumper on each side.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me »</TD></TR><TR><TD CLASS="quote">
HTH</TD></TR></TABLE>
I was gonna say it if no one else did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 »</TD></TR><TR><TD CLASS="quote">
I think its normal when u have swap.
if stock motor then something wrong</TD></TR></TABLE>
I don't think it makes a difference with a swap or not, it's just one of those CRX flaws that everyone deals with.
I have a swap but it happened all the time before i did that.
EL Vap133
15
Oct 24, 2003 08:27 AM
TRE_
Apr 15, 2003 03:54 PM
