my car at the brink of overheating
Old Jun 4, 2004 | 05:39 PM
dawalude's Avatar
Default my car at the brink of overheating
i've noticed recently that when i am driving somewhere and stop at a red light or anywhere for more than a few seconds, my temperature gauge steadily increases until its right below the red mark. what do you guys think it could be? i checked the coolant resevoir thing behind the passanger headlight and its full. i checked the coolant hoses and i dont see any leaks. i don't run with AC on and it happens whether I just got off the freeway, got off work and am waiting at a red light, or dropping off a friend in front of somewhere. what could be possible problems? radiator? thanks for your help!
Old Jun 4, 2004 | 06:14 PM
rubix777's Avatar
Default Re: my car at the brink of overheating (dawalude)
faulty fan switch or thermostat
Old Jun 4, 2004 | 06:15 PM
dawalude's Avatar
Default Re: my car at the brink of overheating (rubix777)
is the fan switch easily replaceable? DIY job?
Old Jun 4, 2004 | 06:17 PM
uncle's Avatar
Does the fan turn on?
Old Jun 4, 2004 | 06:18 PM
dawalude's Avatar
Default Re: my car at the brink of overheating (uncle)
yeah it does
Old Jun 4, 2004 | 06:21 PM
thehondaguru's Avatar
I would start the motor let it idle ans PLEASE watch the temp gauge and just see if the fans turn on. If they do the fan switch is good.
Then if you are POSITIVE you have enough coolant and no leaks try to bleed the coolant because it might just be a bubble.
Next is whenyou just change the thermostat. After that it gets expensive.
Please dont let your motor overheat I accidently did it not paying any attebntion and cracked my old h22 block!
Old Jun 4, 2004 | 07:02 PM
dawalude's Avatar
Default Re: my car at the brink of overheating (95 lude)
thanks i'll give it a try
Old Jun 4, 2004 | 07:15 PM
no prob
Old Jun 4, 2004 | 07:37 PM
ExodusFX's Avatar
Turn your heater on and see if you get hot air blowing out.
Old Jun 4, 2004 | 07:57 PM
dawalude's Avatar
Default Re: (ExodusFX)
hot air comes out for sure, but if i turned on the AC..hot air comes out for maybe a minute then it starts to get cool..then eventually cold. before, it would just be cool right away
Old Jun 4, 2004 | 09:33 PM
del_parker's Avatar
check behind your engine and see if you have coolant leaking out from around the water pump. it's on the driver's side.
Old Jun 5, 2004 | 09:27 AM
vinuneuro's Avatar
Default Re: (dawalude)
check the lines going to your heater core. are you sure that your coolant is ok? Check the coolant level, when the car is cool.
Old Jun 5, 2004 | 10:42 AM
uncle's Avatar
Is the lower radiator hose hot or cold when car is at normal operating temperature? If it's cold then your thermostat is not working.
Old Jul 23, 2004 | 10:35 PM
dawalude's Avatar
Default Re: (uncle)
thanks for all your help guys. i replaced the thermostat, and replaced the radiator with 1:1 mixture of water and coolant
Old Jul 23, 2004 | 11:40 PM
SUB-0 H23's Avatar
had a similar problem like your, check out my thread if you likehttps://honda-tech.com/zerothread?id=931882
Old Jul 23, 2004 | 11:41 PM
dawalude's Avatar
Default Re: (SUB-0 H23)
thanks bro
j3rmit
Jun 1, 2017 03:42 PM
Jamie Steadman
Aug 14, 2015 12:07 PM
Shade93
Apr 13, 2010 01:15 PM
vlude99
Jul 30, 2009 05:58 PM
PureEF8
Jan 20, 2006 06:28 PM
