quick cooling fan question
Old Jun 4, 2004 | 03:36 PM
904drlx's Avatar
Default quick cooling fan question
does anyone know why my cooling fans come on only when i turn th a/c on?
Old Jun 4, 2004 | 03:44 PM
904drlx's Avatar
Default Re: quick cooling fan question (904drlx)
anyone????
Old Jun 4, 2004 | 03:47 PM
1990civicsiguye's Avatar
your cooling fans come on to cool the motor but im sure we all know that ... is you car overheating does it ever get hot ........ we need more info here to help you out also it just might not of got up to temp to turn the fans on . ...... i know here in the winter in florida i have driven twenty min before the fans will kick on so really depends on how long you are running the motor before you turn the car off
Old Jun 4, 2004 | 03:56 PM
904drlx's Avatar
Default Re: quick cooling fan question (1990civicsiguye)
soory i didnt give enouf info, but yeah it will get all the way hot without the fans comming on.
Old Jun 4, 2004 | 04:14 PM
ImportsCRX's Avatar
hmm i thought the fans do come on when ur ac comes on.
Old Jun 4, 2004 | 04:59 PM
Tyson's Avatar
it takes a lot of heat for my coolant fan to come on. the radiator fan automatically comes on with the AC fan and switch. so at least you know its working. i doubt the coolant sensor in the back of the engine is bad, its just your radiator and themorstat doing a good job of keeping temps down.
i did install manual coolant fan switch tho. i use it when im in stop and go traffic and at race events just to be sure.
Old Jun 4, 2004 | 05:39 PM
RedRacerCivic's Avatar
they come on because when ac compressor is turned on, the motor has to work harder to turn the compressor in turn can make the motor overheat easier unless both fans are turned on. Another reason is the condensor fan need to be on to cool the freon passing through the condensor and the radiator fan is a sidekick to keep the motor cool.
Kenneth723
Jun 9, 2019 07:38 PM
jodyboy
12
Aug 15, 2012 09:39 PM
nfiniti9
Jun 9, 2012 02:14 PM
ITB
Dec 5, 2005 06:56 PM
ithrowpoop
Mar 6, 2002 06:19 PM
