check engine lights goes on and off...
Old Jun 4, 2004 | 02:11 PM
gsr93integra's Avatar
Default check engine lights goes on and off...
my check engine lights keeps goin on and off,i got a turbo and i dunno why it keeps on turning on.can somebody help me out....thanks...oh and 1 more thing,how do you adjust the boost on turbo....(newbie) .....thanks
Old Jun 4, 2004 | 02:54 PM
JDM PRO's Avatar
Default Re: check engine lights goes on and off... (gsr93integra)
if it keeps going on and off constantly then something MAJOR is wrong w/ your motor. Check the code and go from there
Old Jun 4, 2004 | 08:07 PM
mtetro99's Avatar
you should have done some research before you got a turbo on your car.
Old Jun 4, 2004 | 08:28 PM
yangtech's Avatar
you should check your o2 sensor to see if it's working, cause i had a bad one and after i replaced it, it doesn't turn on and off anymore... as for the turbo, you'll be some sort of boost controller to adjust your boost...
Old Jun 4, 2004 | 08:45 PM
africanqueen's Avatar
Yeah, I had a similar problem. I would start the car and everything was cool. Then like two miles down the road, the Engine Check Light would pop up. Ever since I got my swap, it has not come up again.
tylerzero
Honda CR-V & Element
Oct 27, 2022 07:21 PM
Tru2Less
Dec 31, 2007 07:17 AM
Guyana00
Oct 19, 2006 06:11 AM
95turbocivicEX
Jun 2, 2004 06:22 PM
