URGENT help on COoLaNT
hi, i need to do a flush so i was wondering
what kind/mix do i need?
i already bought some peak
50/50 coolant premixed ready to use...
is that gonna be fine or should i mix it myself...
1992 integra GSR(b17a)
let me know
let me know
I would not use that coolant. If you look on the back panel it probably says it contains silicates, which is bad for Honda radiators. Use either Honda pre-mixed, Prestone, or Prestone pre-mixed coolant (green colored stuff, NOT red or orange).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">I would not use that coolant. If you look on the back panel it probably says it contains silicates, which is bad for Honda radiators. Use either Honda pre-mixed, Prestone, or Prestone pre-mixed coolant (green colored stuff, NOT red or orange).</TD></TR></TABLE>
I agree with Patrick. Honda/Acura recommends to use low silicate coolants. If I were you, I'd either use Honda coolant or Zerex G-05 coolant. The G-05 coolant is a low silicate formula that's safe for our cars.
Also, don't get hung up on the color. There are green colored coolants that contain silicates and some that don't. For example the G-05 coolant is yellow in color, but is safe for Honda/Acuras.
Secret Chimp
Feb 1, 2008 03:53 PM
T_Rex
Nov 9, 2002 06:21 PM
Duck Sauce
Nov 23, 2001 08:49 AM
