help choose between toda cams
Old Jun 4, 2004 | 11:17 AM
TeamSTEALTH GSR's Avatar
Default help choose between toda cams
motor= b18c1, 1.8L, 12.3:1CR
toda Bs? or Cs
would Cs be too big for that CR?
would Cs make more power then Bs with that CR?
TIA
edit... other mods: ports skunk2 IM, 68mm TB, hondata, rc440, DC ITR header, 2.5" header back. daily driver, gonna run on mixed 94oct
Old Jun 4, 2004 | 11:24 AM
supanatural's Avatar
Default Re: help choose between toda cams (TeamSTEALTH GSR)
toda b's for sure
i think C's too big, kill compression
Old Jun 4, 2004 | 12:00 PM
Quitripin's Avatar
that depends. do you want to kick some a$$? (C) or do you want to idle fine when you come to a street light! (B)
Old Jun 4, 2004 | 12:21 PM
Default Re: help choose between toda cams (Quitripin)
dont care about idle or money(between Bs and Cs)...
just want a nice power band....
if Cs will cause u dip in my midrange, then thats not what i want...
researching, and it looks like Cs recommand 13.1+ CR...
so im leaning towards Bs til i hear more good things about Cs
Old Jun 4, 2004 | 12:23 PM
Quitripin's Avatar
C's is good you just need to degree the cams to avoid the dip
Old Jun 4, 2004 | 01:36 PM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quitripin &raquo;</TD></TR><TR><TD CLASS="quote">that depends. do you want to kick some a$$? (C) or do you want to idle fine when you come to a street light! (B) </TD></TR></TABLE>
I think the B's and C's have the same primary lobes...
Old Jun 4, 2004 | 02:06 PM
AM Specified 39's Avatar
Default Re: help choose between toda cams (GeeReg)
12.2 CR is minimum for spec C's..
12.8 CR is ideal.
I'd go with C's.
An old trick to gain a bit more compression, is to adv the intake cam.
B's and C's.... They both share the same promary lobes just a larger vtec lobe, so I don't think your midrange will be high affected by the bigger vtec.
Old Jun 4, 2004 | 05:59 PM
NSX Bob's Avatar
New User
What does this mean? For the millionth time, B's and C's have the SAME primary lobes. The only difference is on the vtec cam. If you can make B's idle, you can make C's idle. Get the C's. *sigh*
Old Jun 5, 2004 | 04:32 PM
UncleD's Avatar
Default Re: help choose between toda cams (NSX Bob)
Toda's suck, don't de em for cryin out loud. Go to importreview and you'll find SEVERAL dyno charts proving that Toda's arent that great. If you got that money, go Jun 3's, or for less do Skunk 2 stage 2's. Toda's build some good mid-range torque, but thats about all they do well.
Old Jun 6, 2004 | 02:09 AM
Default Re: help choose between toda cams (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Toda's suck, don't de em for cryin out loud. Go to importreview and you'll find SEVERAL dyno charts proving that Toda's arent that great. If you got that money, go Jun 3's, or for less do Skunk 2 stage 2's. Toda's build some good mid-range torque, but thats about all they do well. </TD></TR></TABLE>
ROTFLMFAO
Ok, mr. dyno bot... look at this chart.
<FONT SIZE="3">What do you have to say?</FONT>
Here is a 1.8L chart w/ C's for you, "a low hp" chart doesn't mean low #'s at the track.
Old Jun 6, 2004 | 06:12 PM
woodog's Avatar
Default Re: help choose between toda cams (AM Specified 39)
the b's and c's are basically the same cam. c's just give you an extra 8-10whp on the top.(ask 'toda si' if he still has the comparison dyno tested on his car long ago) they cost about the same price, so why not just go for the tiny little extra lump if you're going to get the todas anyway?
todas don't suck. there are countless 190whp+ toda b/c graphs here posted by numerous members with minimal necessary mods(or at least there use to be) all the way upto 230, 240whp.
the 230whp graph you see above tho, 'the guy' swapped out his c's for the type 3's and put down 254/179.
Old Jun 9, 2004 | 07:39 PM
BLACKekTURBO's Avatar
I THINK THE C'S ARE THE WAY TO GO...YOUR COMPRESSION IS FINE FOR THE C SPEC'S
DRtools
Mar 9, 2009 07:35 AM
.Mason
Apr 11, 2008 08:53 AM
TakumiFujiwara
16
May 10, 2003 06:58 PM
oldskooljdm
Apr 12, 2003 03:28 PM
JDMchris
May 28, 2002 09:55 PM
