ecu question for 91 civic with dohc zc
i recently purchased a 91 civic si with no motor and tranny and i am going to be putting a dohc zc in it.will the stock si ecu work? or is there a better ecu to use?
The Si one will work.
The Integra one will also work - gives better ignition maps, but runs a little rich.
The ZC ECU obviously would be the ideal ECU.
You might want to try out a custom chip in your Si ECU. There should be a ROM floating around out there that has a good ZC tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bo0sT3d_CrX »</TD></TR><TR><TD CLASS="quote">I wouldnt get the zc ecu cuz it pegs out at like 114mph.</TD></TR></TABLE>
shouldn't be doing that on the street anyway!
The ZC ECU will be governed at 114 but that can be removed.
ZC ECU code PM7
88-89 Integra PG7
shouldn't be doing that on the street anyway!The ZC ECU will be governed at 114 but that can be removed.
ZC ECU code PM7
88-89 Integra PG7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C »</TD></TR><TR><TD CLASS="quote">
ZC ECU code PM7
88-89 Integra PG7</TD></TR></TABLE>
THe speed governer, could be remove with a reprogrammed chip
ZC ECU code PM7
South Bay Surfer
Feb 29, 2004 12:10 PM
