my radiator fan wont work, please help
Old Jun 3, 2004 | 10:10 PM
wsiracerz's Avatar
Default my radiator fan wont work, please help
my radiator fan wont turn on, i switched it with my friends radiator fan an it still didnt work, i checked the fuses under the steering wheel an the raditor fan fuse was fine, is there a fuse for it in the engine bay, please help cuz my car gets hot really fast an doesnt go down even with heater on, not sure if it could be thermostat but doesnt seem like it, all inputs help thanks
Old Jun 3, 2004 | 10:28 PM
chrisCNL's Avatar
Default Re: my radiator fan wont work, please help (wsiracerz)
jump the fan switch on the thermostat housing with a paper clip...if you fan comes then you have a bad temp switch. my two cents.
Old Jun 3, 2004 | 11:04 PM
wsiracerz's Avatar
Default Re: my radiator fan wont work, please help (chrisCNL)
where do i jump it at, is it right by the thermostat, jus never had this prob b4 an need some help
Old Jun 3, 2004 | 11:29 PM
boostn420's Avatar
On the thermostat housing there is a 2 wire switch. Thats the fan switch, if you unplug and jumper it the fan will turn on.
Not that it cant happen, but Ive never seen a fan switch go bad. Gets hot really fast, and no fan is most likely a headgasket.
Old Jun 3, 2004 | 11:35 PM
2k.civic.si's Avatar
Default Re: my radiator fan wont work, please help (boostn420)
if u jump the fan switch and it does nothing....check the relay switch....
Old Jun 4, 2004 | 12:30 AM
wsiracerz's Avatar
Default Re: my radiator fan wont work, please help (2k.civic.si)
ok so i jumped the fan switch an it came on, so i will be gettin a new temp switch tomorow at acura, any ideas on the price of these
fatl13ert
Oct 22, 2012 12:41 AM
thisdamnhonda
21
Feb 26, 2012 09:47 AM
kirkland08
Mar 5, 2011 01:15 PM
808MAUI
Feb 23, 2006 07:51 PM
ViXoN Hatch94
Feb 4, 2006 07:53 PM
